Interface impeller/volute
Like Tree1Likes
  • 1 Post By ghorrocks
Old   October 26, 2020, 15:16
Default Interface impeller/volute
Henrique
henriquempr is on a distinguished road
I simulated a centrifugal fan (impeller + volute), using a frozen rotor interface.
In the results I can take two pressure values of at the interface, one for the rotor side, one for the volute side. It turn out that the value are differents (exemple: rotor side- 3729 Pa; volute side: 3483 Pa).
Is the difference normal?
Which value is more correct to use in the calculations?
Many thanks
henriquempr is offline   Reply With Quote
Old   October 26, 2020, 17:02
The interface should have the same pressure at both sides. I suspect the difference you are seeing is due either not matching the same exact point, or interpolation errors. Note CFX uses a sophisticated finite element-like approach which includes evaluation at integration points which are at a finer pitch than the nodes. The results file just includes the nodal values and does not include the integration points. This means interpolation on the results file is not the same as interpolation on the full solver solution values.
henriquempr likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   October 26, 2020, 17:25
Henrique
many thanks
centrifugal impeller, interface, pressure values
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
