STATOR BLADE ORIENTATION
Like Tree1Likes
  • 1 Post By ARJUN
Old   September 14, 2006, 13:35
Default STATOR BLADE ORIENTATION
ARJUN
Dear Friends,
Currently, I am running various cases for an Axial Compressor (single) stage geometry (ROTOR and STATOR).
I have the HUB.curve / SHROUD.curve / PROFILE.curve files for the STATOR. I would like to change the stagger angle of the Stator by few degrees to study the effect only using the three curve files. Basically I need to change the stator angle by 2 / 5 / 10 (degrees) from its current orientation. How can I go about this?
Can I use Bladegen to do this?
I would be gratefull if any one could please let me know steps to be followed and points to be careful about.
Thanking you all in advance.
Kind regards, Arjun
MUSohail likes this.
Old   September 14, 2006, 13:42
Default Re: STATOR BLADE ORIENTATION
Robin
Hi Arjun,
If you are using Turbogrid to generate the mesh, you can specify an axis (as two points) about which to rotate the blade. To do so, edit the "Blade 1" object and click on the Transform tab. The rest should be ovious.
Regards, Robin
Old   September 14, 2006, 23:36
sam
i have done this thing i.e to change the stager angle but that was in gambit. no idea abt cfx
Old   September 16, 2006, 16:23
deLuther
I believe it can be done with Bladegen (or Blademodeler). Bladegen can read turbogrid files.
Old   September 17, 2006, 10:42
sam
It can be easily done with gambit
Changing orientation of object in Paraview Jochem OpenFOAM 0 July 28, 2010 05:52
Face orientation in blockMesh WiWo OpenFOAM 0 March 18, 2010 12:10
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
Y+ orientation Ashish Siemens 1 April 22, 2003 04:58
Orientation in wall-reflection terms applying... Fabio Kasper CFX 0 March 23, 2000 14:06
