September 16, 2020, 01:35 |
CFX SST model with wall function and yplus
James
Rep Power: 6 |
Hello. I've read the CFX manuals and cfd-forums. However, there are some confusions about the yplus and wall functions.
1. Is it correct that SST model in CFX is valid when y plus is in range of 20-200 or less than 1? 2. Does the SST model uses the wall function when y plus is larger than 11, and does not use when y plus is less than 11? 3. What is the velocity profile or wall functions in the calculation process when y plus is larger than 11? I think that it uses the mixture of velocity on viscous sub-layer and log-law region. Does it only uses the profile of log-law region? |
September 16, 2020, 01:50 |
Stuart
Rep Power: 26 |
Did you read this blog series. It is a useful and easy to follow resource:
https://www.computationalfluiddynami...undary-layers/ https://www.computationalfluiddynami...oundary-layer/ https://www.computationalfluiddynami...ow-resolution/ |
September 16, 2020, 02:03 |
James
Rep Power: 6 |
I've now read these article, but any of them cannot be the answer of my question...
September 16, 2020, 06:09 |
Rep Power: 144 |
If you understood what those links are saying then you could answer the questions by yourself. So read them again, and look at some other references for further information. This is important stuff for CFD, so you really should know it.
But I will answer your questions anyway: 1) SST is valid for any y+ value. But make sure you are not confusing the turbulence model with the wall modelling (integration to the wall versus wall functions). 2) Again, do not confuse the turbulence model with the wall model. If you use SST with automatic wall functions then it uses wall functions for y+>11 and transitions to integration to the wall for y+<11. But it is the wall model which does this, not the turbulence model. 3) This is described here: https://www.computationalfluiddynami...undary-layers/ It puts u+ following the log law function, as a function of y+.
February 22, 2023, 13:58 |
#5 | |
Ali
Rep Power: 10 |
February 22, 2023, 15:36 |
Gert-Jan
Rep Power: 28 |
Better read some general theoretical books treating Turbulence. These are full of the value 11.
February 23, 2023, 05:00 |
#7 | |
Stuart
Rep Power: 26 |
sst model, velocity profiles, wall functions, y plus |
Replicating Scalable Wall Function with a UDF | yousefaz | FLUENT | 0 | August 4, 2017 02:30 |
K-kl-transition model y+ | Shamoon Jamshed | FLUENT | 13 | June 17, 2016 14:38 |
Solver Yplus of Automatic wall treatment | justjhy | CFX | 2 | May 4, 2013 07:19 |
YPlus Values and SST Model | Jenny | CFX | 1 | June 22, 2008 18:47 |
