How to export data from 3D streamlines (separately ) ?
Like Tree1Likes
  • 1 Post By Mohamed911
Old   September 15, 2020, 07:18
Question How to export data from 3D streamlines (separately ) ?
Mohamed911 is on a distinguished road
we are simulating a pump using ANSYS CFX ...
We need to generate streamlines, starting at center of each element on the inlet and export the data out. Therefore, if we have n elements on the inlet, n number of streamlines need to be generated. Then, we need to trace each streamline separately and export the relevant information (i.e, pressure, velocity, or any other user defined variable) out for further analysis.
We already created the streamlines at the center of each cell on the inlet in CFD-Post. Then, we exported the streamlines information out as .csv file. However, when we open the file in excel, it is impossible to see which points (nodes) are related to which streamline. We need to be able to distinguish the streamlines from each other.
In another word, we need an excel file, which has a format similar to the following:
Streamline 1
x y z variable1 variable 2 ...... variable m
(number of rows here depends on the number of nodes forming this particular streamline)
Streamline 2
up to the n-th streamline.
Mohamed911 is offline   Reply With Quote
Old   September 15, 2020, 07:36
On the streamline object, under the object tab there is an option "unique". Hopefully you can include this variable in the csv file you export because then it will be the streamline id number.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   September 15, 2020, 11:54
thank you for your suggestion ..
it's not possible to include the option unique when exporting streamlines data but I found that it's possible to include the streamline's number .. that exported data might be messy but it's not a problem to sort them based on the streamline's number
MMoataz likes this.
Old   September 15, 2020, 22:07
Henrique Stel
Stel is on a distinguished road
This is the easiest workaround I'm aware of. But certainly you can go fancier using CCL programming (Macros) with perl language. You can find some examples on the internet.
Stel is offline   Reply With Quote
Old   September 16, 2020, 13:06
I never worked with that ... I guess I'll try try it
Thank you
cfx, data export, streamlines
Data Export in Fluent during calculation Abbasi_Maaz FLUENT 2 March 5, 2021 10:55
[General] How to export space coordinates and scalar data on a slice? milan.senar ParaView 0 February 26, 2019 19:05
Export data in text file Eferal FLUENT 5 April 13, 2018 11:33
CFD Post Data Export Automation hcisby CFX 1 December 23, 2017 18:41
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
