August 22, 2020, 15:09 |
CFX interface error
- None -
Rep Power: 6 |
I am doing a steady state anlysis on a centrifugal pump. In my case the impeller(rotor) is completely immersed in the fluid, hence I created the inlet and outlet on the pump (stator). I meshes both stator and impeller (rotor) separately and added them in the CFX setup. I used the interface frozen rotor. In the error message it says the pitch angle ratio doesn't match with area ratio . I have been lagging with this since 2 weeks. Could anyone please tell me the solution to solve this error. |
August 22, 2020, 23:07 |
#2 | |
Henrique Stel
Rep Power: 17 |
August 25, 2020, 17:56 |
#3 | |
- None -
Rep Power: 6 |
Thanks for your reply. Finally a pitch angle value 360 and topology parameter 2 has solved my problem and the problem is converged. The pressure distribution is very unfamiliar in the post but the output values are matching the experimental values. As you explained I didn't take the side 1 and side2 but I have selected both the sides at a time. Doesn it change the pressure distribution? Can you also tell me the difference between total and static pressure please? |
August 25, 2020, 19:26 |
Rep Power: 144 |
August 25, 2020, 22:15 |
- None -
Rep Power: 6 |
In my case pump is completely immersed in the tank. So can I say my total pressure is equal to static pressure?
Thanks in advance! |
August 25, 2020, 22:20 |
#6 | |
Henrique Stel
Rep Power: 17 |
Glenn's links above should help you, but in short, the total pressure is the sum of the static pressure and the dynamic pressure. It is better understood in the context of the Bernoulli's principle along a streamline, but it is relevant in many areas, such as for estimating a pump head, for example. |
August 25, 2020, 22:25 |
Henrique Stel
Rep Power: 17 |
No, no direct relationship between one thing and the other. You should be familiar with this concept, it is a basic and important one in fluid mechanics. Again, Glenn's links should help you.
August 26, 2020, 02:43 |
- None -
Rep Power: 6 |
[QUOTE=Stel;781333]Selected both the sides at a time? What do you mean?
I haven't selected both the surfaces separately but selected both in a single interface condition! |
August 26, 2020, 02:46 |
#9 |
- None -
Rep Power: 6 |
Actually I am a structural mechanics engineer, it is first time that I am working on fluids m, so very confused about this. I have considered a boundary condition of Inlet - Total pressure and Outlet - Mass flow as I know both the values from the experimental data. I have seen many tutorials with mass flow inlet and total pressure outlet and still confused about it.
August 26, 2020, 03:33 |
#10 |
Rep Power: 12 |
August 26, 2020, 03:44 |
#11 |
- None -
Rep Power: 6 |
Thanks for the reply. I have seen videos on YouTube, ofcourse all of them are not fully reliable. I have used total pressure inlet and relative mass flow rate at outlet (experimentally observed with rotational speed of impeller). I got the value almost equal to experimental when I used total pressure inlet and got a value higher than experimental with status pressure inlet. In the experiment the pump inlet immersed in a fluid. So I am confused if this fluid pressure is static or total.
August 26, 2020, 09:29 |
#12 | |
Rep Power: 33 |
Even for an opening, you may want to read the documentation carefully since the options include an Opening Pressure which behaves as Static Pressure for outflow, and Total Pressure for inflow. Standard practice for steady flow simulations include: - Total Pressure inlet + Static Pressure outlet - Mass Flow Inlet + Static Pressure outlet - Total Pressure inlet + Mass Flow outlet - Total Pressure inlet + Exit Corrected Mass Flow (outlet of course) For transient simulations with incompressible flows, the use of mass flow boundary condition can lead to convergence problems since transient wave propagate too fast and the BC is not flexible enough to change. Hope the above helps,
August 26, 2020, 11:12 |
#13 | |
- None -
Rep Power: 6 |
Thanks for your detailed reply and it cleared all my doubts bout opening pressure and total, static pressure. Thank ou very much |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 10:30 |
