Issue importing surface pressures to shell element for 1-way FSI |
August 6, 2020, 11:42 |
Andrew
Rep Power: 6 |
Hi, I am new to CFD and am really struggling finding a solution to my problem.
I have attached a PDF explaining my issue for full clarity. In short: I can't successfully import pressure values from either CFX or FLUENT onto each side of a shell element in ANSYS mechanical without direction errors. I'm thinking the solution is to make my model a 2D rotating blade element in CFX and import pressures - but I cant get such a model to work - is it possible? I'd be very grateful for any advice, thanks. |
August 6, 2020, 20:07 |
Rep Power: 144 |
I am no expert on FSI, but some comments:
Have you checked the shell elements you are using support FSI? Not all shell element types support FSI. Also read the CFX documentation on FSI and system coupling. There is lots of detail in the documentation.
August 8, 2020, 16:55 |
Andrew
Rep Power: 6 |
Hi, I believe the issue was as simple as changing the scale on one of the imported pressures to -1 rather than 1
OpenFOAM error | Vinay Kumar V | Main CFD Forum | 0 | February 20, 2020 10:17 |
[ANSYS Meshing] FSI Solid mesh only one element thick? | treem22 | ANSYS Meshing & Geometry | 0 | September 22, 2016 15:45 |
Two way Fsi Problem- Non linear problem | kmgraju | CFX | 4 | April 28, 2015 12:15 |
FSI of a shell | Henry Arrigo | CFX | 2 | May 12, 2014 18:15 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 05:08 |
