Axial compressor - Convergence Problem at Near-stall condition |
May 22, 2020, 01:34 |
Tien Dung
Rep Power: 7 |
Hello everyone,
I am trying to obtain the compressor map for the NASA Stage 37 - a transonic axial compressor. I carried steady simulations with 1 rotor and 1 stator, using the SST model. I was able to reach convergence around the design point (RMS less than 10-6, pressure ratio and efficiency also converged). But when I increased the outlet pressure to find the near-stall point, I got an Overflow problem after about 200 steps. I tried to change the physical time step from 0.0001 to 0.05 (include the residence time) but the problem remained. I checked the y+ for converged cases and y+< 2 in almost all areas. I ran the same simulations for this compressor before with the k-e model and it converged quite easily. What do you guys think is the problem? Mesh or boundary condition? Any suggestion is appreciated. Thank you for your time. |
May 22, 2020, 01:40 |
#2 | |
Rep Power: 144 |
May 22, 2020, 02:02 |
Tien Dung
Rep Power: 7 |
Thank you for your reply.
I understand that at stall, the flow is highly transient, and transient simulation is the best option. But in papers I read, they used SST models for similar compressors and obtained reasonable results with steady simulations. As I said, when I used k-e model, the simulation converged and results came quite close to experimental data. Maybe reducing the effect of transient features can help in my case? |
May 22, 2020, 09:26 |
Rep Power: 33 |
You mentioned you increased the pressure to move towards the stall conditions, correct?
For what I understand, the current practice to obtain the operating curve is to use the Exit Corrected Mass Flow option. Once you have obtained a converged solution of your liking, you reduce or increase the specified value to move left/right along the curve using the previous solution as the initial guess. Keep in mind that as you approach the stall point, the reduction in mass flow specification would be smaller and smaller until the simulation no longer converges. You can try using a similar approach using the outlet pressure specification, but you may encounter convergence issues depending on the details of the machine you are modeling. The smoother/uniform the curve towards the stall point, the more difficult to solve it becomes (older practice) Hope the above helps
May 22, 2020, 09:33 |
#5 | |
Tien Dung
Rep Power: 7 |
February 22, 2023, 10:36 |
Dinh Van Son
compressor, convergence failure, sst k-omega |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
Axial Fan boundary condition problem | Turbomachine | CFX | 19 | September 23, 2018 13:20 |
problem of implementing a new solver with a special boundary condition | huyidao | OpenFOAM Programming & Development | 0 | April 27, 2015 09:24 |
Problem with "symmetryPlanne" boundary condition | fcuevas | OpenFOAM Running, Solving & CFD | 1 | March 14, 2012 06:07 |
a problem with Boundary condition | M Rad | Main CFD Forum | 12 | November 27, 1998 13:49 |
