How to generate good quality figures from cfx-post
Like Tree5Likes
  • 5 Post By Robin
Old   June 1, 2006, 15:08
Default How to generate good quality figures from cfx-post
Ken
Hi, all
Can someone provide tips of generating good quality figures from cfx-post for publication?
The default legend is too small. Either screen printing or printing as JPEG gives bad quality figures. The legend and the numbers are hard to read.
Regards,
Ken
Old   June 1, 2006, 15:44
Default Re: How to generate good quality figures from cfx-
Joe
The legend can be extensively modified: View control > Default legend.
Print > Uncheck screen size and set as high a resolution as you need. Increase JPG quality as needed or output as postscipt (i.e. vector image)
Old   June 1, 2006, 16:06
Robin
When generating images for publication, keep in mind that the print resolution for a magazine is typically 200 to 300 dpi, which is 2x to 3x times greater than your monitor. So, what looks good on your screen will look lousy in print (or very small).
As Joe suggests, set the pixel width manually (or specify 200% or 300% of screen size). To calculate the pixel width, find out how big the printed image needs to be then multiply the horizontal and vertical dimensions by the dpi count. For example, if you want a 2"x3" image at 300 dpi, you will need to generate a plot at 600x900 pixels. If your generating an image to print on the front page of a magazine, 8"x10", you will need 2400x3000 pixels.
For images out of Post, I would never use anything other than PNG. It will usually give you the best compression and is completely lossless. If you use JPEG compression, your image will look like crap. PNG uses a similar compression algorithm to GIF, but supports millions of colors (whereas GIF only supports 256).
If you are using version 5.7 or later, the "High Quality" output option will be on by default. I recommend leaving this on. This will anti-alias your plot, making lines, vectors, text, etc. appear smooth. It does this by internally generating the image at twice the size, then resampling the image at the desired resolution. Anti-aliasing will cost you a little on compression (due to more variations in color), but makes for a much sharper looking image.
Finally, images with a white background generally look more professional (or to a lesser degree the default blue to white gradient). There is a "white background" option on the print settings and I recommend using it.
Regards, Robin
mct90, granzoporo, Mfaizan and 2 others like this.
Old   June 1, 2006, 16:43
Joe
Does Yehuda Sinai still work @ CFX?
Old   June 1, 2006, 18:19
Ken
Thanks a lot, Joe and Robin.
A new problem I am getting is that, when I increase the text height to above 0.02, the title of legend will cover the numbers or get too close to the numbers. How to solve this problem?
Best regards,
Ken
Old   June 1, 2006, 18:26
Poldu
Can you do this macros so that you are sure the same plotting option is used for each plot of each simulation. A paper refused my work because the legend/axis/font were not exactly the same for each plot.
Can't you write a journal file for this?
It is important to be rigorous.
Poldu
Old   June 1, 2006, 18:34
Joe
Change text justification to none, then you get access to the position dialog boxes and can enter any value you want.
Come on, its not rocket science ...
Old   June 2, 2006, 09:26
Robin
You can easily reuse the same state. It also helps if you always specify the image size in pixels, rather than use the screen size.
-Robin
Old   June 8, 2012, 05:11
yahya_a is on a distinguished road
hi
i use ansys 13 and in the CFX-Post i dont have "default legend view"
what should i do?
And it is inactive when i right click
http://i.minus.com/iLnCI7KVuoSel.png
yahya_a is offline   Reply With Quote
Old   April 4, 2016, 05:41
Lorenzo Tombari
lorenzotombari is on a distinguished road
Wrong thread
lorenzotombari is offline   Reply With Quote
viewing cfx post while working on cfx solver manager HMR CFX 5 March 9, 2011 23:33
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
(CFX POST) Rotational Speed ARJUN CFX 9 July 13, 2006 21:38
CFX bought by Ansys - good or bad?! Pete CFX 38 February 21, 2003 08:34
Radiation/Heat Flux in CFX Post Soren CFX 1 July 2, 2002 13:55
