Timestep Selector has colored plane for the last step but not others!Why??
Like Tree1Likes
  • 1 Post By AtoHM
Old   April 12, 2020, 06:49
Default Timestep Selector has colored plane for the last step but not others!Why??
Martin
Martin232323 is on a distinguished road
Dear CFD professionals;
In, CFX-CFD-Post - Timestep Selector:
There is 2000 Loaded Timestep with movement but no visualization on the plane at all. (No color- Contour doesn't work on the plane)
Just the final one (2001) has both movements and visual shapes in color on the plane! (Contour on the plane working)
What is the solution to have colored planes (Contour on the plane) for the other 800 timesteps?
Best Regards,
Martin
Martin232323 is offline   Reply With Quote
Old   April 12, 2020, 07:15
M
AtoHM is on a distinguished road
The results shown in cfd post are just the values that are saved during the simulation. The final step will be a .res file containing the standard variables written out by the solver.
Other timesteps in the timestep selector should only be available if you wrote some intermediate results. In a transient simulation, these would be .trn files which are saved in a subfolder of the simulation folder. Now if you can access another time step in post but do not see the desired contours, your intermediate .trn file does not contain these values and therefore cfd post cannot display them. You need to check in your simulation setup what values you write to your intermediate files.
aero_head likes this.
AtoHM is offline   Reply With Quote
Old   April 12, 2020, 09:24
Martin
Hi
Thanks for your answer!
I selected every Timestep and after the run, I had just answers for the last timestep.
According to the pictures please reflect your idea! Especially for the options in Trn.
Best Regards,
Martin
Old   April 12, 2020, 16:56
M
As it says, your intermediate results are partial. Are you sure you selected all the variables you need for your contour plot?
In your last images "Output variables list". Check these.
Old   April 12, 2020, 19:12
Martin
Dear AtoHM
Yes, it is partial. (In the other projects when it is partial it works)
I'm sure that the selection for the last picture was done!
Please check the new picture. Is it the reason or not? (how can I repair them?)
If not how can I make colored contour planes for others?
B.R
Martin
Old   April 13, 2020, 05:15
M
Afaik this is just a warning and can be ignored, I don't know about the beta feature, though. Never seen that.
What variables are you trying to show on your contour?
Old   April 13, 2020, 05:26
Martin
Pressure, Velocity, Velocity in Stn Frame
Old   April 13, 2020, 05:43
Smile
Martin
It solved!!!
Velocity is right not Vorticity!!!!
Dictation problem!
Because the fonts are small and I use my tiny small laptop!
Thank you so much!
Your last question helped so much!
Happy Easter and have a nice day!
cfdpost, cfx, timestep selector
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
