March 29, 2020, 06:46 |
Frequency calculation
Rep Power: 15 |
How can I calculate the frequency of a flow phenomen?
Assuming I have a unknown frequency at 480 Hz based on FFT analysis, does it mean a unkown flow phenomenon is reapted with 1/480 period? |
March 29, 2020, 17:57 |
Rep Power: 144 |
I don't understand your question. If you have done an FFT and got a peak at 480Hz all that means is that it is picking up a 480Hz signal. Pretty obvious really. What that 480Hz signal is and whether it is known or unknown is up to you - you have not provided any details so we cannot help you further.
March 30, 2020, 01:58 |
Rep Power: 15 |
Yes, there is a peak at 480 Hz. I understand that!
I’m simulating a compressor near to stall, so I’m expecting to see the frequency of stall cells that rotate around the annulus. Stall cells are defined as low axial momentum or reversed flow regions. The attached images show FFT result and axial velocity fields upstream of the rotor leading edge. As seen, low axial momentum is accumulated at the tip. I wonder if you could please tell me how to approximate the frequency of these low axial momentum regions and whether it is 480Hz? |
March 30, 2020, 02:07 |
Rep Power: 144 |
I don't know what parameter you have taken an FFT for, or which point it applies to. I don't know what the low axial momentum regions are in your image and I don't know what your geometry is. I also don't know how the stall cells propagate around the circumference.
So I am doing a lot of guess work here. But don't you simply work out from your simulation how fast you anticipate the stall cell to propagate around the circumference?
March 30, 2020, 03:01 |
#5 | ||
Rep Power: 15 |
According to the literature, a stall cell propagates between 20% to 70% of the rotational speed of the rotor. The regoins of low axial momemtum have been marked in the image. The pressure signal was recorderd at IGV/Rotor interface and then the FFT analysis was made. Quote:
Are you using circumferential velocity and radius to approxiamte the rotational velocity of stall cells? |
March 30, 2020, 04:53 |
Rep Power: 144 |
I still don't know much about what you are asking.
Are you saying the literature says the recirculation cell, when just on the stall point, travels around the circumference at 20%-70% of the rotor speed? And that the rest of the flow remains attached with no significant recirculation? If you have modelled this using only two blades I would not think you would be able to pick up this sort of phenomena. I would think you would need a full rotor model (or at least a lot of blades, maybe half the rotor).
March 30, 2020, 09:48 |
#7 | ||
Rep Power: 15 |
I would like to find the source of that 480 Hz. Is that really the frequency of the low axial momentum region (stall cell) or it is because of something else? Quote:
Yes, exactly but it may not occur exactly at stall point. The exact point of stall cell formation is not known. Nevertheless, it starts as part-span stall and then evolves into a full-span stall cell. Quote:
I have modelled just one passage. According to the literature, at least two or three passages are required to find the frequency of stall cells propagation around the annulus. Having said that, what I need to know is a way to approximate the rotational speed of the low axial momentum assuming it is a stall cell. |
March 30, 2020, 17:58 |
Rep Power: 144 |
To see what is causing the 480Hz peak you have to save lots of transient results files and look at them trying to pick some disturbance which is 480Hz. It may or may not be the stall point motion you suggest, you should keep an open mind until you find the source. But you should definitely look to see if it is the stall point motion.
I would have thought that to get the speed of the stall point progression you would need to model at least two passages (and preferably more), and then measure the time it takes to progress from one passage to the next. Then multiply by the number of total blade passages and you have the time to travel around the circumference.
March 31, 2020, 03:13 |
#9 | |
Rep Power: 15 |
Assuming this low momentum region causes a disturbance that has some frequency, is it possible to approximate the frequency or rotational speed of this recirculation zone from velocity vectors? Is it correct to approximate the rotational speed assuming the recirculation has a circular motion? I’ve tried to create an animation showing the velocity vectors at the same turbo surface at different time steps but it was not successful. |
March 31, 2020, 05:39 |
#10 |
Rep Power: 144 |
Have a think about what you are actually modelling here. When you model a single blade passage you make the implicit assumption that all passages are the same as the modelled one. This means by definition your single passage model cannot predict the separation travelling around the circumference as that would require the passages to be different (ie some with a recirculation and some without).
That is why I said a few posts ago that you will not be able to predict the motion of this recirculation with a single blade passage and you will need a full rotor model.
March 31, 2020, 06:26 |
#11 | |
Rep Power: 15 |
I've compared all frequencies at the operating points from choking to stall points. This frequency (480 Hz) just shows up at near stall so I think it is somehow connected to stall point. |
March 31, 2020, 06:58 |
#12 | ||
Rep Power: 144 |
March 31, 2020, 10:04 |
#13 | |
Rep Power: 15 |
Now I understand why the frequency of rotating stall cannot be predicted in this way. Sorry to bother you again but now that I know the frequency at 480 Hz might be caused by the low momentum region (recirculation zone), how can I confirm it? |
March 31, 2020, 17:13 |
#14 |
Rep Power: 144 |
It can be difficult to spot what is actually causing the spike in your FFT at 480Hz. All I can suggest is to record an animation of your results and try to pick a flow which is near that frequency.
Dynamic mesh adaption in parallel calculation | xh110120 | FLUENT | 1 | March 12, 2016 08:05 |
Determining the calculation sequence of the regions in multe regions calculation | peterhess | OpenFOAM Running, Solving & CFD | 4 | March 9, 2016 03:07 |
Calculation of Vortex Shedding Frequency From Lift Coefficient | shantanukale | OpenFOAM Post-Processing | 1 | April 6, 2015 10:53 |
Overhang Cavity Acoustics : Helmholtz Frequency Calculation | ashish_singh | Main CFD Forum | 0 | May 18, 2009 07:40 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
