March 28, 2020, 05:50 |
CFX error code 1
Rep Power: 6 |
I was trying to run simulation of a compressor stage with a single fluid sector to reduce computation. After completing the setup in Cfx-pre, When I try to run the simulation, The solver stops with the following errors. The ANSYS CFX solver exited with return code 1. No results file | | has been created. ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Floating point exception: Overflow | | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine FPX: C_FPX_HANDLER | | I am new to CFX and checked various other threads but couldn't find the exact issue. I am using ANSYS 19.2. |
March 28, 2020, 06:00 |
Rep Power: 6 |
| Mesh Statistics | +--------------------------------------------------------------------+ | Domain Name | Orthog. Angle | Exp. Factor | Aspect Ratio | +----------------------+---------------+--------------+--------------+ | | Minimum [deg] | Maximum | Maximum | +----------------------+---------------+--------------+--------------+ | Diff | 35.8 ok | 10 ok | 4 OK | | Impeller | 3.1 ! | 243 ! | 1435 OK | | Inlet | 44.8 ok | 10 ok | 4 OK | | Global | 3.1 ! | 243 ! | 1435 OK | +----------------------+---------------+--------------+--------------+ | | %! %ok %OK | %! %ok %OK | %! %ok %OK | +----------------------+---------------+--------------+--------------+ | Diff | 0 <1 100 | 0 2 98 | 0 0 100 | | Impeller | <1 7 93 | <1 4 96 | 0 0 100 | | Inlet | 0 <1 100 | 0 1 99 | 0 0 100 | | Global | <1 6 94 | <1 4 96 | 0 0 100 | +----------------------+---------------+--------------+--------------+ |
March 28, 2020, 06:31 |
Rep Power: 6 |
Update,
So, I tried to run the simulation with different material i.e Air and it converged in 25 iterations. So maybe it is the material that is creating the problem because I added the material manually in the setup. But I think I should add it through an another method like adding through CFX text files. am I right? |
March 28, 2020, 06:42 |
M
Rep Power: 13 |
It is perfectly fine to add everything in the GUI. I only know one thing that cannot be added in the GUI but must be provided by ccl file ... maybe there are a few more, but in most of the cases you can do everything in the GUI. Overflow is a common issue which can be caused by material and boundary condition settings. Check the forum FAQ on that.
March 28, 2020, 10:03 |
Rep Power: 6 |
Thank you for the reply.
I am wondering if the problem is due to boundary conditions, it shouldn't work with other material like Air at 25 Celsius. Maybe the error is caused by wrong material properties because I have to use another material and I manually added it in GUI. |
March 29, 2020, 01:31 |
Rep Power: 144 |
Here is the link to the FAQ. It is the place to start: https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F
March 29, 2020, 13:05 |
Rep Power: 6 |
Yes I checked that thread yesterday. I believe its the material properties that are creating trouble because the same setup with Air works fine which is default. So, I think that's the properties.
Thank you |
ansys 19.2, cfx, error 1, solver crash, turbo machinery |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 08:08 |
High Resolution (CFX) vs 2nd Order Upwind (Fluent) | gravis | ANSYS | 3 | March 24, 2011 03:43 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 14:22 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 06:59 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 05:47 |
