Regarding boundary conditions
Like Tree5Likes
  • 2 Post By Gert-Jan
  • 2 Post By urosgrivc
  • 1 Post By Opaque
Old   March 18, 2020, 21:53
Default Regarding boundary conditions
Basivi Reddy
basivi is on a distinguished road
I want to calculate pressure drop,
Reference pressure: 1atm
Total pressure (stable) at inlet: 20psi
Static pressure at outlet: 0pa
Fluid: water
Pressure drop: area average total pressure at inlet - area average total pressure at outlet.
Is this the right approach? any suggestions or corrections?
basivi is offline   Reply With Quote
Old   March 19, 2020, 06:04
Have you read the CFX documentation on choosing boundary conditions? It has some good tips on which combinations of boundary condition work well.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   March 19, 2020, 06:30
Gert-Jan
Gert-Jan will become famous soon enough
a massflow average would be better than an area average.
Gert-Jan is offline   Reply With Quote
Old   March 19, 2020, 07:24
urosgrivc
urosgrivc is on a distinguished road
What you are setting up is not ok...
You have specified a pressure drop as a boundary condition (inlet 20psi outlet 0pa)
this is the answer (you must not set the answer to your problem as a boundary condition, because where is the point then?)
If you want to get the pressure drop as a result from the simulation:
you would have to specify either Inlet or Outlet pressure and mass flow (or velocity which is the same thing)
Now you would be able to get pressure drop as a result
What you have done by setting inlet and outlet pressure (you have fixed the pressure drop) from this simulation result would be mass flow or any of the flow velocities
urosgrivc is offline   Reply With Quote
Old   March 19, 2020, 07:45
Gert-Jan
I do not agree. I think the setup is ok. Total pressure includes the dynamic pressure component which is unknown from the start since the velocity is yet unknown.
So, it depends on definition of pressure drop. You cannot take the difference between total pressure on the inlet and static pressure on the outlet.
It is either difference in total pressure or difference in static pressure.
But from a bernoulli point of view it is best to take the difference in total pressure.
The total pressure on the oulet is not known yet. It will be the outcome of your simulation. So I think your setup is ok. However, as mentioned earlier, I would take the mass flow average instead as area average.
urosgrivc and basivi like this.
Old   March 19, 2020, 07:56
Basivi Reddy
Yes, also I am confused, maybe because I am reading a lot or mixing up different scenarios I read on the forum with my case.
Old   March 19, 2020, 07:59
Basivi Reddy
Noted, thanks.
Old   March 19, 2020, 08:03
Basivi Reddy
I think the same.
How to approach the problem if I know only static pressure at inlet? and outlet is open to the atmosphere?
Old   March 19, 2020, 09:10
urosgrivc
In this case, I would add a large 'buffering' volume on the outlet, so the Boundary condition opening is not close to the actual 'thing (a nozzle, exhaust or whatever)' of interest, actually to simulate a part of the surrounding
This simulation would run with pressure inlet condition and opening pressure on the far-field boundary condition
the outlet, in this case, is opened to the atmosphere
The simulation is transient in this case but can be steady-state of course
in this case, Pressure drop in the muffler is obtained from the simulation as it is a part of the solution
maybe you can be more specific about your simulation as I can see we did not understand ourselves previously
Gert-Jan and basivi like this.
Old   March 19, 2020, 09:43
Basivi Reddy
Thanks for the reply.
1. My area of interest is to study pressure drop between inlet and outlet.
2. I am simulating UV-C water filter (no porous media inside). Based on the pressure drop data, I have to suggest changes to design.
3. I have experimental data, which are, a) Pressure (don't know whether it is static pressure or total pressure, please see the digital gauge setup) at inlet which is 20 psi, b) outlet mass flow rate 2 liters/min.
4. I finished a case without specifying massflow rate because i want to know massflow rate at outlet,
Boundary conditions:
Total pressure at inlet 20 psi, outlet static pressure 0pa
result: massflow rate at outlet: 4.4 liters/min, area average total pressure at outlet is 0.1psi.
Old   March 19, 2020, 15:18
Opaque will become famous soon enough
Your setup is sound since your inlet is a Total Pressure condition, i.e. a plenum upstream.
On the appropriate average to use, I would stick to areaAve ONLY because we are talking about a momentum balance, and pressure is force/area
In the case of momentum, or enthalpy transport I would definitely use massFlowAve since accounts for the total advected quantity.
an easy way to see is by integrating the transport equation over the whole domain which by the Gauss theorem becomes a surface integral, and you must balance
areaInt (mass flux * Velocity),
areaInt (wall shear)
areaInt (pressure )
and so on. You can then replace the areaInt by areaAve () * Area.
There you go. Hope it helps,
basivi likes this.
Opaque is offline   Reply With Quote
Old   March 20, 2020, 02:22
Question
  #12
Basivi Reddy
can anyone help me understand this,
1. Which pressure difference I have to consider? ('case 2' and 'case 3' pressure difference is close)
2. Is specifying mass flow outlet in 'case 2' as 0.03 kg/s (experimental result) correct approach?
Old   March 20, 2020, 03:17
Gert-Jan
Sorry to be blunt, but clearly you don't understand the real basic things of hydrodynamics. I would suggest to try to understand Bernouilli equation before performing CFD calculations.
A suggestion would be to perform multiple cases with increasing velocities on the inlet and 0 pressure on the outlet. Then use Excel to plot Total/Static/Dynamic pressures versus velocity/massflow/volumeflow.
Old   March 20, 2020, 04:04
Basivi Reddy
Okay Thanks.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 10:49
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
