sign of mass flow rate
Like Tree1Likes
  • 1 Post By Opaque
Old   March 11, 2020, 09:57
Default sign of mass flow rate
phd
lostking18 is on a distinguished road
Hi, there
I’m a bit confused about the mass flow definition in CFX. I know that when the surface norm is opposite to the flow direction, the mass flow rate calculated by ‘ massFlowInt(1)@A1 ’ is negative. But what is the definition of the surface normal direction in CFX? Also why some of the mass averaged quantities, such as temperature, computed by ‘ massFlowAve(Temperature)@A1 ’ is negative? If it is also because the surface norm is opposite to the flow direction, why sometimes the ‘ massFlowInt(1)@A1 ’ has different sign with the ‘ massFlowAve(Temperature)@A1 ’?
Thank you in advance!
lostking18 is offline   Reply With Quote
Old   March 11, 2020, 10:31
Opaque will become famous soon enough
ANSYS CFX uses the following convention:
Incoming quantity is positive,
Outgoing quantity is negative,
Incoming increases content, Outgoing decreases content.
If you want to formulate it via the Normal direction:
Opposite directions --> incoming
Same directions --> outgoing
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   March 11, 2020, 16:03
phd
Hi, Opaque:
Thanks for your reply. I think your definistion works when at the boundary of the computational domain. But what if it is the surfece inside the compuatational domain? Supposing a 45 degress axial cut plane in the middle of the compuational domain, it has both incoming and outcoming flow. So I think it really depends on how we define the normal direction of the surface. I'm not sure how this is defined in CFX.
Old   March 11, 2020, 18:13
phd
More specifically, I found at area A1, the mass flow computed by:
massFlowInt(1)@A1
always have different sign comparing to
areaInt(Normal X*Velocity u*Density + Normal Y*Velocity v*Density + Normal Z*Velocity w*Density )
I don’t know what is the reason for that difference.
Old   March 12, 2020, 10:49
A surface in space w/o reference between interior and exterior does not have a well defined normal. It is whatever you want to make it.
Say, you take a plane in space defined by a Normal, and a point away from the Normal and it looks identical in space to the one using -Normal.
The Normal is arbitrarily defined. The important issue if that both results can only be different by the sign, and that the Normal is uniformly defined over the whole surface.
lostking18 likes this.
Old   March 13, 2020, 12:27
phd
Hi, Opaque, from my observation, it seems that the norma is pointing to the convex side of the curve.
mass flow average
Shape Optimization Problem of Mass Flow Rate ggc1991 SU2 Shape Design 1 December 1, 2016 21:24
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 11:40
Mass Flow rate in DPM model tohidtkz FLUENT 0 November 7, 2015 05:13
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 14:14
Mass Flow Rate is not converging destgir448 CFX 5 December 11, 2010 06:55
