Defining area value in CFX-post
Like Tree1Likes
  • 1 Post By evcelica
Old   January 16, 2020, 10:36
Default Defining area value in CFX-post
itb7 is on a distinguished road
Hello all,
I am trying to create a chart in CFX-post that will display the drag coefficient. I've created an expression to determine the drag coefficient:
(2*force_x()@airflowdomain )/ (AR*den*(InletVel)^2)
where AR is the surface area of the object in question and den is the fluid density. However, the value being returned is a Cd of 0.0038, which seems very very low.It seems to me there must be a mistake I've made in determining the force being exerted over the front of the object, but I'm not sure where.
Any suggestions/advice would be greatly appreciated!
itb7 is offline   Reply With Quote
Old   January 13, 2021, 00:25
Kira
aero_head is on a distinguished road
There seems to be an error in your equation.
If the velocity is aligned with the x-axis, you could obtain the drag coefficient as Cd = force_x()@Surface / (0.5*Rho*U^2*A)
There is also a thread that you could go through to troubleshoot your issue(s); http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
aero_head is offline   Reply With Quote
Old   January 13, 2021, 12:54
Erik
evcelica is on a distinguished road
1.) As aero_head states: location for force_x() should be the surface object in question, not the domain.
2.) "AR" should not be the surface area, but instead the cross sectional area normal to the flow direction.
aero_head likes this.
evcelica is offline   Reply With Quote
cfx-post, drag coefficient, expressions, variable definition
export expression from CFX post owarlow CFX 5 November 12, 2019 17:43
CFX Post Expressions number decimals njiang CFX 3 December 13, 2013 05:39
CFX post legend modification mactech001 CFX 3 December 25, 2011 23:12
CFX Post export problem jeff_F CFX 0 August 17, 2009 22:25
CFX Post processing aditya CFX 1 July 6, 2008 13:09
