Error iif_set_lock when solving heat transfer problem. |
Rep Power: 0 ![]() |
I'm trying to use ANSYS CFX to solve a fluid-solid heat transfer problem. I followed the following online tutorial guide step-by-step (http://www.youtube.com/watch?v=-xNXlp344SA). When I run the solver, the results seem to be converging, but eventually, after CFX writes the transient file 4_full.trn, the solver ends and I get the following error message:
ERROR #001100279 has occurred in subroutine ErrAction. Message: iif_set_lock: file zFas3A4b is currently locked for writing, and cannot be locked for read access. Either another program is using this file, or the lock file zFas3A4b.lck is bad. P.S. I have added the solver output file as an attachment. Last edited by flytoceres; December 17, 2019 at 16:35. |
Rep Power: 144 ![]() ![]() ![]() ![]() |
This is a very unusual error, so something weird must be happening on your system. Check you have not run out of disk space, check that things like virus checkers are not crippling your system (even better, turn the virus checker off when doing simulations), don't write output files to network drives (write them to the local machine) and things like that. The problem is CFX is not getting reliable access to the hard drive, so look into anything which might compromise that.
ansys cfx 19, error iif_set_lock, heat transfer, parallel calculation, solid fluid contact |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
