December 9, 2019, 21:32 |
Full Porous Model and Multiphase
Lucas
Rep Power: 7 |
I have a simple doubt which I couldn't figure it out by reading the documentation: when I use the full porous model, CFX considers that the porous domain is a phase? So If I have a homogeneous mixture of gases percolating a porous medium I will a mulphase and multicomponent problem or I will have only a multicomponent problem? |
December 9, 2019, 22:57 |
Rep Power: 144 |
CFX does not regard the porous material as a phase or a component. It regards it as a resistance to the flow. If you are doing heat transfer it will also regard it as a solid - but not a multiphase model.
multiphase flow, porous domain |
What multiphase model for porous media modelling | Sabby | FLUENT | 3 | January 16, 2018 09:43 |
multiphase cylindrical flow through porous medium; BC | adrianabm | OpenFOAM Running, Solving & CFD | 1 | September 7, 2015 11:37 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
multiphase flow in porous media | zhou | FLUENT | 2 | August 9, 2012 08:10 |
