Locating the location for a specific value
Like Tree1Likes
  • 1 Post By ghorrocks
Old   November 28, 2019, 06:45
Default Locating the location for a specific value
Max
Xamilia is on a distinguished road
I am simulating a shock tube in fluent and want to postprocess it in CFD Post. To locate the shock in the current time step I want to use the pressure.gradient X. To plot the position against x and t I need to now where the value is max. But I don't find a way to get this information. So can someone help me how to find the x-location of the shock?
Thank you
Xamilia is offline   Reply With Quote
Old   November 28, 2019, 06:48
I can't see a way to do this in CFD-Post. You could try a full featured post processing software like tecplot, fieldview or ensight.
Alternately, when I was doing shock tube work I often used the pressure half way between the before and after shock pressure. You can then put a contour line on it and extract the location of the contour line for a chart.
Xamilia likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   November 28, 2019, 07:18
Max
Thank you for your quick answer!
Oh okay.
I just found a way to extract the position with a Point and the Method 'Variable Minimum', in the Chart I selected the Location of this Point. Problem is that the pressure.gradient isn't the greatest at the shock in the beginning, it is in the area of expansion waves. Only after a while it does work for the shock.
Your idea seems to work better for this case, but I am not sure if I understood your way exactly. How do insert the contour line with the specific pressure value? It would be very kind if you could explain it in a little more detailed way, thank you very much!
And if I find another way, I'll let you know if you're interested.
Thanks!
Old   November 28, 2019, 17:24
Insert a contour object, and change the levels to be a pressure level you define. Then you can get the XYZ location of the contour line using functions like max, min, ave etc of the contour object.
cfd - post, chart, expression, location, position
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
