Decreased Mass Flow Rate for Same Gometry with Increased Temperature? |
November 13, 2019, 06:59 |
nicola
Rep Power: 10 |
Hello, I couldn't figure this out.
There is no heat transfer in the system. I've just used temperature dependent variables for fluid (n-heptane). Things like density, viscosity, evaporation pressure are changing with respect to temperature. I have two case with excatly the same dimensions. With higher temperature case (75 Celcius) mass flow is lower in the same cross section inside the domain compared to lower temperature case (25 Celcius). There isn't any separation or evaporation that can limit the hydraulic diameter in that section. So what can cause this mass flow deviation? Is it due to lower density? But how about lower viscosity? Due to lower resistance, flow will have higher velocity. Since the cross section area is fixed, shouldn't mass flow rate increase in this case? |
November 13, 2019, 17:21 |
Rep Power: 144 |
If you have variable density, viscosity and evaporation pressure with temperature then anything could happen. With the vague details you have provided we can't help you. You are just going to have to look at your results and figure it out - compare the velocities, densities and everything else so you know the complete picture.
Specify mass flow rate for periodic boundary conditions in channel flow | lion1990 | OpenFOAM Running, Solving & CFD | 1 | July 9, 2018 18:46 |
Mass flow rate boundary condition with negative values | hebe2u. | CFX | 1 | December 27, 2016 04:53 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 11:40 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Mass Flow Rate Error | jallison | FLUENT | 1 | May 16, 2011 17:22 |
