Temperature profile with isothermal steady state simulation
Like Tree2Likes
  • 2 Post By Opaque
Old   November 6, 2019, 09:22
Default Temperature profile with isothermal steady state simulation
Procyon
Procyon is on a distinguished road
Hello everybody,
I would like to do a steady-state simulation with an Aungier-Redlich-Kwong fluid model. I have a temperature distribution, i.e. a function Temperature(x, y, z) that was measured in a test rig (actually, it does not matter. It could be the result of another simulation or something else). Now I want CFX to use this temperature distribution.
Every time I insert an expression into the "Fluid Temperature" field in Details of Domain -> Fluid Models -> Heat Transfer, CFX complains that only a constant value or an expression evaluating to a constant is allowed.
Is there a way to specify a temperature distribution for a steady-state, isothermal simulation?
The problem is that I need to match the measured temperature distribution, but I do not know any heat fluxes at the walls.
Thank you for your answers,
Sincerely,
Procyon
Procyon is offline   Reply With Quote
Old   November 6, 2019, 09:44
karachun's Avatar
karachun is on a distinguished road
"Isothermal" mean that temperature remain constant in domain and time and there are no heat transfer. Change Domain Heat Transfer model to Thermal Energy or Total Energy to be able to use temperature distribution.
karachun is offline   Reply With Quote
Old   November 6, 2019, 10:16
Procyon
Originally Posted by karachun View Post
"Isothermal" means that temperature remains constant in domain and time and there is no heat transfer.
I know. The temperature distribution that I want to apply should stay constant and not change with time. It should change with position (x,y,z), not with velocity, pressure, density, ...
Actually I just want the solver to evaluate fluid properties (density, viscosity, etc) at a prescribed temperature T(x,y,z) that varies with position and not at a constant temperature T.
That only allows me to set an initial temperature distribution. The Temperature distribution in the domain will immediately change unless heat flux boundary conditions match the conditions in the test rig. But since I do not know the heat flux boundary conditions, this is not possible, or involves a lot of trial and error.
Old   November 6, 2019, 10:38
karachun's Avatar
1) Plz. read definition of term "isothermal". Domain will have single temperature. There is no variation of temperature in space. OK?
https://en.wikipedia.org/wiki/Isothermal_process
2) If you know only initial temp. distribution then you can only calculate transient problem and observe how temperature change over time. Steady-State mean that time is infinite and temperature will change to value affected by BC setting, you can use different initial distribution, result will be the same.
Old   November 6, 2019, 11:21
Procyon
I know what isothermal means.
The point is, in an isothermal simulation the energy equation is not solved and the temperature field is not a result of the calculation. The temperature is needed only to calculate fluid properties. Therefore, it does not matter to the solution procedure if the temperature is constant or if it varies with position. Ansys could have easily implemented this feature. If they did, then the term "isothermal" would be misleading, and "prescribed temperature field" would be much more accurate.
My question was whether there is a (hidden?) way to prescribe a temperature field.
Old   November 6, 2019, 15:24
Opaque will become famous soon enough
It is not a good idea to mix vocabulary based on behavior.
Isothermal means the same temperature in the domain; therefore a single value must be provided.
The models that provided temperature variation are Thermal Energy/Total Energy. Therefore, you must select one of them.
Now that you have the ability to provide a temperature profile, you want to freeze the solution just after the initial value has been provided, and before the solution of the heat transfer model starts.
you can realize that behavior by
Use Thermal Energy option
Initialize using Automatic with Value = YourTemperatureProfile
Inset the Solver/Expert Parameters panel, and choose "solve energy = f" in the appropriate tab.
You should get the behavior you want. Now you have to be very careful the solution makes any sense since you have removed the ability to satisfy energy conservation.
Procyon and karachun like this.
Opaque is offline   Reply With Quote
Old   November 11, 2019, 13:06
Thumbs up
Procyon
Thank you! This is exactely what I was looking for!
isothermal flow, steady state, temperature distribution
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Convergence in steady state simulations vs transient ones cardioCFD CFX 5 January 21, 2018 11:59
How to split a steady state simulation streamline90 OpenFOAM Running, Solving & CFD 8 October 19, 2017 16:55
Averaging during a steady state simulation say CFX 3 November 3, 2015 10:18
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
