CFX error: Variable is not allowed to have a component name prefix |
September 16, 2019, 13:38 |
Abdullah Arslan
Rep Power: 7 |
Hi all,
My mixture name is MSR and while using CCL I am getting this error. The variable 'p' referenced by parameter 'Flux' in object '/FLOW:Flow Analysis 1/DOMAINefault Domain/BOUNDARY:Catalyst/BOUNDARY SOURCE/SOURCES/EQUATION SOURCE:CH4.mf' is not allowed to have a component name prefix. I have changed the formula for instance: MSR.CH4.p to simple CH4.p but what other prefix there can be? P.S CH4.mf depends on CH4.p |
September 16, 2019, 14:41 |
Rep Power: 33 |
Why do you expect p (as in pressure) to accept a component suffix? Are you expecting partial pressure? that behavior is not supported in ANSYS CFX
p, when used in property evaluations, is effectively the Absolute Pressure. For other expressions, it is safer to just refer to Absolute Pressure directly and avoid confusion/problems. |
September 16, 2019, 15:17 |
#3 | |
Abdullah Arslan
Rep Power: 7 |
pabs*CH4.molf =CH4.p actually, i formulate the equation as it is in paper but didn't realize that partial pressure term should be replaced in other form |
ccl, cfx |
Error: Update failed for the setup component in Fluid Flow CFX | nudi1001 | CFX | 4 | January 17, 2023 04:01 |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 17:38 |
how to define a not-moving chemical component in CFX? | cardioCFD | CFX | 5 | January 22, 2018 19:36 |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 03:20 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
