Error about import mesh from CFD to CFX
Like Tree2Likes
  • 2 Post By rosswell
Old   January 17, 2006, 06:39
Default Error about import mesh from CFD to CFX
Stephen
Dear all,
I got a problem on mesh generation in ICEM CFD 5.1-CFX. For creating geometry, i used Solidwork 2005 and saved it as Step file. After importing geometry to ICEM CFD 5.1-CFX, i created parts such as inlet, outlet. I generated the mesh successfully.
Then i wrote output and named as xxx.msh file. Exiting ANSYS ICEM CFD-CFX and starting CFX-Pre. When importing the mesh, it said there is a error. I don't know why?? Or it may be wrong for me to use Solidwork? Please help me!!
Stephen
Old   January 17, 2006, 09:51
Default Re: Error about import mesh from CFD to CFX
KBanks
There should be no problem with using solid works. What is the error message and how is the grid quality?
Old   January 18, 2006, 03:25
TB
How could anyone help if you don't tell us the error message? Make sure you have checked your mesh (under "Edit Mesh") and its quality before you write your mesh file. If you generate your mesh successfully, you should get a *.uns file when you save your project.
Old   January 18, 2006, 17:26
I bet the problem is the import format in CFX-Pre. When you import the mesh in CFX-Pre from ICEM CFD you need to specify the format as "ICEM".
Regards, Glenn Horrocks
Old   January 20, 2006, 05:42
Stephen Lau
The error is: " ERROR The file named "gtm.gmo" does not exist.
Unable to import the requested mesh: Type ="Generic". File ="c:/xxx.msh". Generic options="-n". Specific option=::.
Old   January 20, 2006, 06:24
TB
Hi...Have you chosen Output Solver to be ANSYS CFX? It seems to me that *.gmo is not ICEM to CFX format.
Old   May 11, 2009, 02:37
hun
hung is on a distinguished road
It works fine with xp, but when i upgrade the system to vista this problem happen>
Can anyone know how to solve it?
thanks,,
Hung
hung is offline   Reply With Quote
Old   May 5, 2011, 14:05
Default take a look at the directory path
rosswell is on a distinguished road
Well, if it still helps anyone after 2 years, I have just had the same problem but with a correct .cfx5 mesh file and stuff. The problem was that my directory path contained an accent character, which turns out, is unacceptable for CFX-Pre. Apparently spaces are not welcome as well.
Problem solved for me.
Katha and latermary like this.
rosswell is offline   Reply With Quote
Old   June 27, 2011, 10:02
June
examosty is on a distinguished road
I met the same problem. Thank you rosswell. It still helps.
examosty is offline   Reply With Quote
How to import mesh from icem cfd to star cd jopawipr STAR-CD 4 November 9, 2012 16:18
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
how to use ICEM CFD mesh in CFX MareK CFX 8 October 15, 2007 11:43
CFX mesh import from ICEM (Windows) Andrew CFX 7 July 6, 2006 12:39
