varying contact area of splashing oil with surface |
August 29, 2019, 07:55 |
rakesh p e
Rep Power: 10 |
Hi guys,
I was attending a transient two phase flow problem in which an oil is splashing over the surfaces around it. initial contact area is defined. I wanted to find the contact area variation of oil with time. Can anyone help me. |
August 29, 2019, 08:13 |
Svetlana Tkachenko
Rep Power: 15 |
What are the other substances, which are not oil? Please draw the initial conditions and what you expect to occur.
August 29, 2019, 19:52 |
Rep Power: 144 |
The CEL expression areaInt(oil.Volume Fraction)@surface name will give you the wetted area of a phase called "oil" on a surface named "surface".
September 10, 2019, 07:27 |
rakesh p e
Rep Power: 10 |
i have two phases, one is oil and other is a gas. at initial contact area is defined. but on the transient run, oil will splash around and the varying contact area is what i am looking for.
hope you got an idea.. |
September 10, 2019, 07:28 |
#5 | |
rakesh p e
Rep Power: 10 |
September 10, 2019, 07:30 |
#6 | ||
rakesh p e
Rep Power: 10 |
I will try this way. |
Monitor surface area of an oil slick floating on water | visitor | FLUENT | 0 | November 3, 2014 10:53 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 08:22 |
Surface integral calculation by undefined area | Bloshchitsyn Vladimir | CFX | 0 | November 18, 2007 23:19 |
Cross section and surface area factor | Fabiana | CFX | 0 | January 10, 2006 00:51 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
