Modeling double diffusion in a cavity with CFX
Like Tree9Likes
  • 1 Post By mariam.sara
  • 2 Post By ghorrocks
  • 1 Post By Svetlana
  • 1 Post By ghorrocks
  • 1 Post By Opaque
Old   August 1, 2019, 12:13
Default Modeling double diffusion in a cavity with CFX
mariam.sara is on a distinguished road
Dear all,
I am attempting to simulate a double diffusion (Heat trasnfer+Mass transfer) problem in a square enclosure in which there is a high concentration at the left wall (a thin film where the evaporation occurs) and low concentration at the right wall (cold wall where the condensation occurs) as illustrated in picture. May somebody guides me if I it is possible to solve this problem in CFX and which model I can use at the simulations.
Mariam
Svetlana likes this.
mariam.sara is offline   Reply With Quote
Old   August 1, 2019, 18:09
Yes, you can do this in CFX.
The heat transfer is modelled using the normal heat transfer methods in CFX.
The mass transfer can be modelled by a few approaches:
* If the mass transfer does not affect material properties then you can use an additional variable approach.
* If the mass transfer affects material properties then use a multicomponent mixture approach.
In both of these mass transfer approaches you can apply similar boundary conditions to the heat model - dirichlet, neumann etc.
mariam.sara and Svetlana like this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   August 1, 2019, 18:22
Thanks for the valuable answer. May you tell me where I can find the multicomponent mixture approach? Is there any tutorial assist me at the problem setup?
Old   August 1, 2019, 18:33
Svetlana Tkachenko
Svetlana is on a distinguished road
https://www.sciencedirect.com/scienc...29549317304478 for example ?
https://www.youtube.com/watch?v=BfdbkNTkElo
mariam.sara likes this.
Svetlana is offline   Reply With Quote
Old   August 2, 2019, 03:30
Many thanks guys for the answer. Can I make the flow as Boussinesq? i.e. I want to model Boussinesq flow with different fluid concentrations at the cavity side walls? knowing that the cavity is filled with humid air?
Mariam
Old   August 2, 2019, 03:44
Boussinesq was a wide ranging researcher. Which Boussinesq approximation are you talking about? Buoyancy linearly varies with temperature, surface waves or eddy viscosity in turbulent flows? (https://en.wikipedia.org/wiki/Boussinesq_approximation)
Old   August 2, 2019, 04:13
The buoyancy caused by temperature difference only.
Old   August 2, 2019, 04:26
OK, in that case it is easy. Use a thermal energy model with a material which has a constant density but a thermal expansivity defined. That is all you need for that buoyancy model.
Old   August 2, 2019, 04:39
OK what about mass transfer among the boundaries (as my illustration on my first post) can I couple it with the Boyonancy effect?
Old   August 2, 2019, 07:44
As I said in my previous post, you can do the mass transfer by either an additional variable or multicomponent mixture depending on how the mass transfer affects material properties.
Old   August 2, 2019, 09:12
Opaque will become famous soon enough
You can do it, but you need to use the multicomponent approach. That is,
define a variable composition mixture material
assign the material as a fluid to your domain
activate the buoyancy model, set gravity
activate the model for each of the mixture components
set appropriate boundary conditions
Opaque is offline   Reply With Quote
Old   August 4, 2019, 17:27
I attempting to follow the steps you mentioned but I face a problem in setting the mass fraction of H2O vapor at the side boundaries of my geometry because all boundaries in it are walls? and in wall BC I think adding mass fraction is unavailable?
Old   August 4, 2019, 17:29
Svetlana Tkachenko
Can you specify it in the initial conditions? Then it will be conserved during the simulation.
Old   August 4, 2019, 17:38
But if I defined it at the initial conditions it will take it to the whole domain? I want a specified value at the right and left walls?
Old   August 4, 2019, 17:43
Svetlana Tkachenko
Initial conditions are for the whole domain, not only on the boundaries.
Old   August 4, 2019, 17:50
But I do not want set it to the whole domain? I want to specify it just at the boundaries? Each BC has a different concentration.
Old   August 4, 2019, 18:12
Svetlana Tkachenko
Sorry, I did not realize that each BC has a different concentration.
Enable 'Species transport' in your models. Then your wall boundaries will have a 'Species' tab, where instead of 'zero diffusive flux' you can specify the mass fraction of the species. (Please note that someone may need to check this is correct, I have not modeled this kind of physics before.)
Old   August 5, 2019, 05:23
Sorry I did not know how to enable the "Species transport" I went through default domain> fluid models it not exist? May you send me illustrated picture?
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
condensation kz21 Fluent Multiphase 3 February 23, 2018 05:56
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Modeling Fluid Drop in CFX taywrex CFX 1 November 6, 2013 07:08
Multicomponent diffusion modeling gsbhatia89 CFX 2 June 8, 2010 19:31
