Streamline does not appear from the interface
Like Tree2Likes
  • 2 Post By ghorrocks
Old   July 30, 2019, 11:37
Default Streamline does not appear from the interface
Overijssel
SSapkota is on a distinguished road
I am designing a pump blade. While calculating the performance of the centrifugal impeller, I do not see the streamlines from the rotor-volute interface. I thought that the streamline of the whole rotor-volute domain could be visualized when I selected the streamline to start from the Inlet. But, it stops in the interface. The solution is converged and the head and efficiency criteria are met but I wanted to see the overall flow from inlet to outlet to map the turbulent regions. Is it because I have a huge gap (50 mm) at the rotor-volute interface? The interface is frozen rotor with pitch change set to automatic. Thanking you.
Suman
SSapkota is offline   Reply With Quote
Old   July 30, 2019, 11:50
Abdullah Arslan
Goenitz is on a distinguished road
Hi
it seems like some of your domain are switched off. Anyway, try just for inlet pipe domain then go to all domain.
Goenitz is offline   Reply With Quote
Old   July 30, 2019, 22:20
Are you sure your interface is working correctly? Your 50mm gap does not sound good. Look in the output file at the report on interfaces and see if you have a large non-overlap region. Also, in the post-processor look at the non-overlap variable which shows where your interfaces are not joined.
I suspect your interface is not connecting because of the big gap.
Goenitz and SSapkota like this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   July 31, 2019, 05:32
Default Problem Solved
Overijssel
Thank you Goenitz. The problem was not in the domain.
Thank you Ghorrocks. Like we speculated, the problem was in the Gap. Keeping the gap at 1 mm did the trick.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
