July 12, 2019, 04:00 |
Modeling of previous concrete in a channel
yaseen
Rep Power: 11 |
Hello everyone
I want to model previous concrete in a channel of flowing water, I want to know how much water infiltrate through the previous concrete and how much pass over it,can it be done using ANSYS-CFX? How? How to set the boundary at concrete? https://www.cfd-online.com/Forums/at...1&d=1562914798 |
July 15, 2019, 08:48 |
urosgrivc
Rep Power: 12 |
In your case, I would start researching
(a) Porous media (b) Multiphase flow |
July 18, 2019, 14:19 |
yaseen
Rep Power: 11 |
July 19, 2019, 06:27 |
Rep Power: 144 |
I don't know what you are modelling or why, but if I guess what you are doing then I suspect you want to model the previous concrete as a porous material. If you are asking how to set up a porous material - then look in the CFX tutorial examples and CFX documentation.
July 19, 2019, 17:07 |
#5 | |
yaseen
Rep Power: 11 |
I want to model: a channel of water, at a section of the channel, there is previous concrete at the bottom of the channel it work like a filter, part of water moves down through the concrete (since its previous) and part of water pass over it, I want to know how much water pass through the previous concrete |
July 19, 2019, 21:40 |
Rep Power: 144 |
It sounds like my previous comment was correct then - "you want to model the previous concrete as a porous material. If you are asking how to set up a porous material - then look in the CFX tutorial examples and CFX documentation."
July 20, 2019, 07:30 |
yaseen
Rep Power: 11 |
(Help!) Concrete Pipe Loading Test Modeling | sgsalman | ANSYS | 1 | May 16, 2018 18:09 |
modeling entering two phase flow in open channel flow | hesamabtahi | FLUENT | 0 | May 2, 2018 11:13 |
open channel flow modeling | Danial1992 | FLUENT | 0 | March 25, 2017 05:31 |
Modeling of an open channel | rkmittal1108@gmail.com | FLUENT | 0 | October 10, 2012 18:29 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 15:49 |
