Non-uniform velocity at outlet when using mass flow rate boundary condition
Like Tree1Likes
  • 1 Post By karachun
Old   June 9, 2019, 10:52
Default Non-uniform velocity at outlet when using mass flow rate boundary condition
Julian121 is on a distinguished road
I am applying total pressure and total temperature boundary conditions at inlet to solve a problem. At outlet, I am using mass flow rate boundary condition.
Although I have applied the mass flow rate at the outlet, the velocity at the outlet is not uniform.
At the inlet, the velocity is uniform.
Is there a problem at the outlet?
Julian121 is offline   Reply With Quote
Old   June 9, 2019, 21:43
Your inlet graph shows the velocity is 16m/s or above. It does not say it is uniform.
The mass flow outlet condition has a number of different settings, but by default it does not apply uniform velocity across the outlet. Have a look at your mass flow outlet setup and change the option if you want it to be uniform. But I suggest this is not a problem, if the flow wants to be uneven then it probably is uneven and you should let it do that.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   June 10, 2019, 04:14
karachun's Avatar
karachun is on a distinguished road
Maybe this link give some clarity.
https://en.wikipedia.org/wiki/Entrance_length
It will be strange if flow remain uniform in channel IRL.
Julian121 likes this.
karachun is offline   Reply With Quote
In a transient simulation at any instant, should the mass flow at inlet be equal to mass flow at outlet to satisfy the conservation of mass?
Old   June 10, 2019, 08:39
Opaque will become famous soon enough
Depends:
1 - Are you working with an incompressible fluid? YES
2 - Are you working with a compressible fluid? NO
Opaque is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 07:00
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 09:16
Radiation interface hinca CFX 15 January 26, 2014 18:11
