Mesh file of ansys 14.5 can't be opened by ansys 19.1! |
May 20, 2019, 04:57 |
Hamda
Rep Power: 8 |
My problem is that I can't open mesh files created by ansys 14.5 by ansys 19.1. any ideas? Many thanks in advance. Hamda |
May 20, 2019, 05:50 |
Gert-Jan
Rep Power: 28 |
No one is doing that on a regular basis. So, you need to provide more details. We can't read your mind, nor your screen.
- what mesh file (ICEM, ANSYS meshing?) - where do you get the error? - do you have a mesh file (gtm) or a .def file? Or a .res-file? - what error? |
May 20, 2019, 06:33 |
#3 | |
Hamda
Rep Power: 8 |
when I select Mesh in workbench and then import my mesh file it gets green tick and every thing is ok but when I want to see it or better to say I want to edit it I got error , the mesh is opened but there is no mesh and I cant use any button and option and have to close it hardly(by task manager) |
May 20, 2019, 06:41 |
Gert-Jan
Rep Power: 28 |
Can be anything and not necessarily be a problem of 14.5 to 19.1.
I have little experience with Workbench. Try CFX stand alone and see if you can import the mesh. Then still: - what error doe you get - Share a screenshot. - can you open it in Fluent? |
May 20, 2019, 07:08 |
#5 | |
Hamda
Rep Power: 8 |
Yes I can import my mesh to cfx or fluent. Regarding the errors please look at the attached files. |
May 20, 2019, 07:22 |
Gert-Jan
Rep Power: 28 |
So, what you are actually doing is opening a file from ANSYS Workbench Mesh v14.5 into ANSYS Workbench Mesh v19.1.
You are in the wrong forum. Try the ANSYS-meshing and geometry forum. |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 12:32 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
