How to define the inlet using an Interpolation Functions or Data sheet? |
May 15, 2019, 12:01 |
Rep Power: 7 |
Hello , I want to use the mass flow rate as the inlet, before I just defined it as constant value or write in the expression and use a function. However, the function what I used is just an approximate fuction calculated from my experiment date, that was not realistic. So now I just want to input the time point and the correspond mass flow rate, like create an Excel data and then use choose the ''Tool'' - ''Initialize Profile Date'' to upload the excel data (is that true, I don't have experience)?
I will try that and want to know, what is the right form to write in the excel? Like: Time point [s] mass flow rate [kg s-1] 0 0 0.5 1.25 1 2.1 1.5 3.2 2 3.9 ... I tried, but it said ''Invalid format''. How could I input the data in a right way? Thank you! |
May 15, 2019, 17:23 |
Erik
Rep Power: 23 |
Just create a user function in cfx-pre.
You can either type in the data points, or import a text file with just 2 columns of data (numbers only). Define the units of the independent variable time [s] and result variable [kg/s]. Then use this function as your inlet mass flow condition: MyFunctionName(t) |
May 16, 2019, 03:58 |
M
Rep Power: 13 |
https://www.sharcnet.ca/Software/Ans....html#i1310599
I attached an example with variable mass flow. Once imported into pre you can reference the profile by its expression as MassFlowRate.Mass Flow Rate(Time) within the boundary setup. |
May 17, 2019, 06:12 |
#4 | |
Rep Power: 7 |
Thank you! |
May 17, 2019, 06:20 |
#5 | |
Rep Power: 7 |
Thank you! I succeed in using txt to write the fuction. The pic is shown as flowing: 1111111.PNG And then in the inlet using the user function, after loading it likes MFR.Mass Flow Rate(), then the only thing needs to be done is add the Time like MFR.Mass Flow Rate(Time). |
May 17, 2019, 06:27 |
Rep Power: 7 |
[solved and further question delete]
November 26, 2023, 19:00 |
#7 | |
Rep Power: 4 |
June 12, 2024, 17:08 |
breno H
Rep Power: 7 |
Does this works for fluent as well, the same file format? I am trying to solve a CHT problem in fluent using my cfx user function but I cannot find a way to add interpolation functions in fluent. Can anyone show me how?
June 12, 2024, 18:00 |
#9 | |
Rep Power: 33 |
https://ansyshelp.ansys.com/account/...tml?q=profiles
data profile, initialize profile date, inlet, transient |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 08:31 |
How to assign the inlet B.C using a bunch of data set for an unsteady problem? | ali8500 | CFX | 3 | March 28, 2012 19:41 |
how to provide accurate inlet boundary condition from experimental data? | swe704 | FLUENT | 0 | September 29, 2009 05:01 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
