October 21, 2005, 07:16 |
Physical size of geometry in DesignModeler
Hi
I'm trying to import a IGES solid (generated in Rhino) into DesignModeler 9.0, but runs into the problem that if the physical size is above 1000 m, then DesignModeler will not import correctly (creates surfaces instead of solids). If I scale it down to say 900 meters it will import without problems. Did the programmes think that no geometry is above 1000 m. ? And why can't you select km or miles as units ? I tried to play around with tolerances without any luck. Also I have tried to scale it up within DesignModeler. However, when it goes above 1000 m. the program makes an error say that the model exseeds DesignModeler size limith Is there anybody who knows a workaround ? Best regards Michael |
October 21, 2005, 13:05 |
Re: Physical size of geometry in DesignModeler
Please refer to the DM manual. It has stated the fact, but just did not give a reason.
October 21, 2005, 13:21 |
Thanks
I did not look in the manual, because I was sure this was a undocumented bug. - apparently not! Regards Michael |
October 21, 2005, 21:30 |
Maybe you can cheat DM by scaling your model with a factor, e.g., 1/1000. Basically, DM will see the physical size of your geometry is about 1m. After you get a mesh for this model, you can scale mesh back to its original unit. However, doing this may loss the details of small feature in your model.
October 23, 2005, 11:09 |
Aaaahhh that worked !!
Thanks! Although I havent tested it all the way, I had no problem scaling the mesh within PRE and defining domain and so on. Best Regards Michael |
August 29, 2012, 07:40 |
How to scale my modle in design modeler?
Sammer
Hi
I have imported my geomtry into design modlere, and I need to scale it to its real size, just wondering if this option is available in design modeler please? I appriciate your help. Regards Sammer |
August 29, 2012, 08:49 |
Rep Power: 144 |
Yes, DesignModeller can do scaling.
From memory it is an option under "Body operations". |
August 29, 2012, 17:59 |
Sammer
Many thanks for your help. Very helpfull.
Sammer |
June 16, 2017, 02:26 |
Large geometry
#9 |
Niaz
Rep Power: 9 |
Hello .i hav a problem.can u please help me out in this
can i construct geometry/domain with dimension 1000m in x direction, 4000m in y-direction and 100m in z direction in Design molder of ANSYS FLUENT. and what is the maximum size i can construct in DM of fluent |
June 16, 2017, 04:27 |
#10 | |
Antoine
Rep Power: 10 |
Firstly you are in the CFX Forum and not FLUENT/ANSYS Meshing & Geometry. If you want to get a better answer you should post there. Secondly you should try to build that and see if it works. Best way to know. Wazdq |
[DesignModeler] import geometry in DesignModeler | idir | ANSYS Meshing & Geometry | 7 | July 19, 2016 19:43 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
[Gmsh] Problem with geometry. | Andrea_85 | OpenFOAM Meshing & Mesh Conversion | 1 | January 6, 2011 09:34 |
How to modify geometry size in Gambit | Axius | ANSYS Meshing & Geometry | 1 | November 29, 2010 15:21 |
OpenFOAM 13 AMD quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 1 | November 11, 2007 00:23 |
