Dimitrios S. P.
Rep Power: 8 ![]() |
Hello everyone.
Here is another question. My problem is that I have liquid flow in two domains that have a common interface. The interface allows a mass flow to one direction which is analogous to the wall shear stresses that are applied to it. How can I model it in CFX, since I cannot write any conditional flow. |
Rep Power: 144 ![]() ![]() ![]() ![]() |
Have you looked at the options available to interfaces? You can specify a mass flow rate at interfaces, and you could make that a function of wall shear stresses or other variables.
Dimitrios S. P.
Yes, but this applies an equal distributed mass flow to the interface, not an variable one.
Then maybe make it a standard conservative connection, but use a momentum source term to control the flow locally as a function of anything you like.
Dimitrios S. P.
This would have been a good solution,
if cfx had enabled an option of momentum source in interfaces. Unfortunately, cfx fails to my expectations again. What do you thing of the idea of creating a thin subdomain, instead of just a surface, and apply in it momentum sources? |
The thin subdomain can work.
I can't check now, but I thought you could put source terms on interface boundaries. You have to put it on the boundary face, not the interface object.
Dimitrios S. P.
i will try the option of defining a thin subdomain for the thin surface,
since CFX does not allow the modeling of both an interface and a boundary on the same surface. Thanks for your help Glenn! |
#8 | |
There is no such thing as a source term boundary condition - you apply source terms as additional terms on existing domain features.
#9 |
Dimitrios S. P.
But interface's sides also do not allow momentum sources, only continuity sources.
#10 |
OK, thanks for that. I was not at my workstation so could not check that.
In that case the thin subdomain might be the best way forward.
conditions of interfaces |
Modeling the gas flow through the packed bed of DEM particles | Legat | STAR-CCM+ | 6 | January 17, 2024 08:58 |
modeling entering two phase flow in open channel flow | hesamabtahi | FLUENT | 0 | May 2, 2018 10:13 |
Viscoelastic flow modeling in rotorstator system | vulda | OpenFOAM Running, Solving & CFD | 4 | December 25, 2017 03:01 |
mold flow modeling | Pei Hsieh | Main CFD Forum | 0 | May 4, 2005 10:08 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
