Y+ value
Like Tree1Likes
  • 1 Post By ghorrocks
Old   March 1, 2019, 04:19
Default Y+ value
Pedro Oliveira
oliveira1820 is on a distinguished road
I am using the k-epsilon turbulence model in my simualtion for modelling the water behaviour inside a recipient. For the boundary lenght , density fluid value, dynamic viscosity and typical fluid velocity values of my simulation, the estimated wall distance for obtaining a y+ value of 30 is 0,002 m. The problem is that my recipient is only 0,004 m, long, therefore, the first mesh element will occupy half the recipient.
Is this right, or what can I do to oberride this and have a mesh which trully correpsonds to the k-e model?
oliveira1820 is offline   Reply With Quote
Old   March 2, 2019, 09:46
kyaha is on a distinguished road
For k-e model, 30<Y+, is ok
kyaha is offline   Reply With Quote
Old   March 2, 2019, 11:35
Julian121 is on a distinguished road
k-e is a high Reynolds turbulence model which means that it does not have good prediction in a boundary layer. So, y+ should be larger than 11.
Julian121 is offline   Reply With Quote
Old   March 3, 2019, 05:57
Are you saying your pipe is only 4mm long? What is the diameter of the pipe? Are you modelling anything else upstream or downstream?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   March 3, 2019, 06:01
Julian - your comment is a bit mixed up. k-e does not model the laminar sublayer well which is y+<11. This is why a standard wall function boundary condition should not be used under y+<11. But k-e models the loglayer pretty well and this is part of the boundary layer, so this part of the boundary layer is well captured most of the time.
So your comment should be k-e does not have good prediction in the laminar sublayer, so y+ should be >11.
Julian121 likes this.
Old   March 4, 2019, 03:17
Pedro Oliveira
The "pipe" is conical and is only 4 cm long and has initial 2cm and final1 cm of radius. The cone is filled with water which is heated and water doesnt enter or exits, only flows inside the cone.
Old   March 4, 2019, 18:15
What is driving the flow? Is it driven by convection from the heating?
Old   March 5, 2019, 00:15
Pedro Oliveira
Yes, it os driven by convection from heating
Old   March 5, 2019, 00:19
Have you calculated the Rayleigh Number of the flow? Is it laminar or turbulent? Steady or transient?
