Output transient body forces in text file during analysis
Like Tree1Likes
  • 1 Post By urosgrivc
Old   February 27, 2019, 04:20
Default Output transient body forces in text file during analysis
karachun's Avatar
karachun is on a distinguished road
Hi guys!
I model laminar (Re~100) vortex shedding of circular cylinder using CFX in pseudo 2D. I perform transient calculation One of the main goals is to compare Strouhal number with theoretical values. To do so I have to output time history of lift force and calculate period it oscillation.
One varialt of solving this problem is to save full transient results (not all, but rather each 5 or 10 to get reasonable chart resolution and size of result files) and postprocess them in CFD-Post. However, this is disk space consuming way and creation of one chart in CFD-Post can take 5-10 minutes long.
So my question: Is it possible to save body force results during calculation in separate text file (I monitor body forces during calculation using expression so this calculation "on fly" is possible but I don’t know how to extract this data) without saving thousands of transient result files?
Thanks in advance.
karachun is offline   Reply With Quote
Old   February 27, 2019, 05:15
urosgrivc
urosgrivc is on a distinguished road
You could make a Monitor point, and set it in output controls to be plotted while the solver is running.
then Export the values from the solver monitor of only force for all timesteps
karachun likes this.
urosgrivc is offline   Reply With Quote
Old   February 27, 2019, 05:31
karachun's Avatar
Thanks, the solution was very simple, just press RMB on monitor screen
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 15:30
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
