How to change the volume porosity during calculation? |
Rep Power: 8 ![]() |
Dear CFX users
Does anyone have the experience to change the volume porosity during the calculation? Imagine we get a moving bed reactor. If we handle this case with porous media, the volume porosity has to be pre-set, which denotes to e0. However, the voidage of the solid may change with the reaction conditions and the internal heat/mass transfer state. And it can be described using a set of empirical formulations that relevant to the inner state, which is represented by e. If we return the modified e to e0 and keep iterating till convergence, thus we can get more realistic results. This can be done manually by stop the solver and reset the volume porosity according to the last simulation results. But it’s extremely tedious and takes ages to converge. The question is how can I update the volume porosity during the calculation with an interval of certain iterations? (BTW, I tried the User Fortran routine, but every time I update the volume porosity it returns an overflow error. This error was not observed in terms of other parameters, say Velocity and additional variables ) Any advice is appreciated! Thanks and regards! |
Erik
Rep Power: 23 ![]() |
Sounds like you are using the "true velocity" porous model? I can see changing the volume porosity would eliminate or create mass, really messing up continuity. This may not be possible since it goes against conservation of mass.
hi evcelica
Thanks a lot for your reply. Yes, you are right. "True velocity" is adapted in my model. Your explanation sounds solid. it may go against the mass conservation. sorry to be a pest, do you have any suggestion to take into account the variation of the solid-void with the current porous model? |
Erik
Can you just use the superficial model and increase the loss coefficient and decrease permeability so that is equals the same pressure drop characteristics as the "true velocity" model.
I believe it is mathematically equivalent to use: Permeability Superficial = Permeability True * porosity Kloss Superficial = Kloss True / (porosity^2) There may be very slight differences between the two models, which may or may not be applicable to your model. Some posibilities I can think of are: 1.) Transit time for the fluid to flow through the domain would be slower. 2.) Conversion from static to total pressure will be lower using Superficial in high velocity flows, which may not reflect the correct density in compressible fluids. I'm sure there could be other differences, the documentation may describe more. I'm just saying while the pressure drop equations can be made identical, there may be other small differences between the two models. A simple test model could be run to check how equivalent they are in all aspects. |
Rep Power: 33 ![]() |
May I ask what kind of variation you are using for volume porosity?
Based on the configuration files for the software, it seems volume porosity can be a function of position (x,y,z) and time. Have you tried a time-dependent variation? The equations as described in the theory documentation support for variation in time. However, you must be aware that for an incompressible fluid a variation in volume porosity will trigger a pressure wave at infinity speed since the displaced volume/mass must leave the domain immediately to satisfy the continuity equation. Summary: a proper set of boundary conditions and time stepping is required to be able to solve such a problem. |
#6 | |
Much much appreciated for your advice. I will have a test and shift to the "superficial model" |
#7 | |
Thanks a lot for your attention! In my case, the volume porosity is a function of position (x,y,z) and internal state (Solid T, Solid composition). Thus I need to modify the volume porosity after I get the aforementioned filed information. Using a time-dependent variation might be a solution. I will check the documentation to see whether it suits my situation. Cheers |
Rep Power: 7 ![]() |
Hi @longderson, did you try varying the volume porosity with time? I would be interested to know if it worked out as I am facing a similar problem. Thanks
#9 | |
Thanks for your time! |
#10 |
For a single domain, constant properties fluid, you can set up the case as true velocity and superficial velocity and you should obtain an identical solution (barring round off errors).
Of course, the permeability/loss parameters must be set up consistently as Evcelica described. The null test is to set them up with porosity of 1, and check. Then another value and check. You should be able to verify those relationships directly. Once you have multiple domain with flowing passing through interfaces, the solution may be slightly different depending on the interface is set up. |
#11 | |
Thank you for your time again! |
#12 |
I do not think you want to model a pressure wave at infinite speed, the time step would be prohibitive
There is no such thing as an incompressible fluid, perhaps you need some compressibility in your model if that is the real issue. |
#13 | |
porous media flow, user fortran |
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel | Mehrez | OpenFOAM Running, Solving & CFD | 10 | May 18, 2016 11:44 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
water in piston whose volume doesn't change | junbbung | FLUENT | 5 | November 8, 2010 11:02 |
interDyMFoam - change in volume fraction | gopala | OpenFOAM Running, Solving & CFD | 0 | April 27, 2009 10:46 |
