Using "opening" to simulate plane flying through air |
February 18, 2019, 18:56 |
Thu Win
Rep Power: 9 |
Can I use an "opening" to simulate a condition where the plane is flying through the air?
February 18, 2019, 19:32 |
Rep Power: 144 |
It depends.
A vague question gets a vague answer.
February 18, 2019, 19:33 |
Thu Win
Rep Power: 9 |
Depends on?
I am simulating a plane at cruise, so I think the "box" of the wind tunnel could be set as an "opening" with 0 relative pressure. What do you think? |
February 18, 2019, 19:40 |
Rep Power: 144 |
It depends on the Mach number you are simulating, numerical stability considerations, how the boundary is implemented and many others.
The normal way of modelling a body in far field flow (this is the technical term for what you are trying to do) is to put a box around the body with an inlet where the flow goes in and outlet where the flow goes out. Inlet/Outlet pairs tend to be more numerically stable than openings. You need to do sensitivity analyses to find out how close you can put the inlets and outlets to the body - 5 chord lengths upstream for the inlet and 20 chord lengths downstream and to the side would be a good starting point.
simulate a barrel with fluid inside and air above the fluid | richard_vega | OpenFOAM | 2 | October 7, 2019 09:20 |
Air to Air Heat Exchanger | visser1975 | FLUENT | 2 | November 10, 2012 14:34 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
TRANSIENT HEAT & BOUYANCY IN CONFINED AIR | Carl | CFX | 1 | September 25, 2006 10:48 |
How i can to simulate the air flow over the car? | fernando vicente | CFX | 3 | August 11, 2003 23:35 |
