Shell and tube heat exchanger simulation
Like Tree3Likes
  • 1 Post By evcelica
  • 1 Post By ghorrocks
  • 1 Post By Opaque
Old   February 14, 2019, 13:45
Default Shell and tube heat exchanger simulation
Aja
aja1345 is on a distinguished road
I am simulating a Shell and tube heat exchanger. But I face with the following error, why does this happen?
BC is as flollows:
Hot inlet: velocity 1 m/s- temperature 95 c
Hot outlet: 0 pa relative static pressure
Cold inlet: velocity 1 m/s- temperature 12 c
cold outlet: 0 pa relative static pressure
Thanks.
aja1345 is offline   Reply With Quote
Old   February 14, 2019, 17:01
Erik
evcelica is on a distinguished road
Why is this whole thing one domain? It should be 2 separate domains?
Try changing the expert parameter it recommends to 1.2.
aja1345 likes this.
evcelica is offline   Reply With Quote
Old   February 15, 2019, 02:27
Aja
Thanks, you are right. Error solved but I faced with other problem. when I display streamlines in CFD-Post, I see that some stream lines inter to tube zone!!(please see the following picture). Am I right?
This could be due to wrong Interface because one interface is as follows:
and other Interface is as follows:
In setup, there is such message:
I am grateful that guide me in these cases.
Thanks.
Old   February 15, 2019, 04:56
You appear to have set a fluid-fluid interface. So the fluid just goes straight through it, as you asked it too.
You probably either want to model the pipe as a solid domain to separate the two fluid domains, or use a thin wall to separate the two fluid domains but allow heat transfer.
aja1345 likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   February 15, 2019, 05:09
Aja
Thanks your reply.
Yes, you are right. I want to model the pipe as a solid domain to separate the two fluid domains, or use a thin wall to separate the two fluid domains. But because I didn't create a cell zone as a solid domain(thickness of pipe), I want to use thin wall to separate the two fluid domains. How?
Thanks..
Old   February 15, 2019, 16:19
Opaque will become famous soon enough
In the snapshot of the interface you showed, go to the Additional Models tab.
Check the options for Mass and Momentum, and select as needed.
aja1345 likes this.
Opaque is offline   Reply With Quote
Regarding change of tube material of shell and tube heat exchanger kkj1234 FLUENT 0 October 16, 2016 23:39
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent medogalal FLUENT 3 December 30, 2015 05:28
shell and tube heat exchanger... ganesh chakravarthi CFX 3 July 6, 2015 19:44
Analysis of shell and tube heat exchanger in Ansys Dena FLUENT 0 June 12, 2015 14:39
Plate and tube heat exchanger simulation jatin FLUENT 0 June 16, 2014 05:12
