December 19, 2018, 06:28 |
Reynolds number in Turbogrid
Rep Power: 7 |
I'm looking for suggestions:
In turbogrid it is possible to change the Reynolds number on which the mesh is based, then I was wondering, since I'm studying a transonic rotor both at Design point then off design conditions, if I should change the Re for the off design meshes, or if I could simply use the same mesh I've used at Design Point Thank you in advance |
December 19, 2018, 16:37 |
Rep Power: 144 |
Generate both meshes and see if the difference is significant.
December 20, 2018, 10:10 |
Rep Power: 7 |
Thanks, actually I've done two simulations with two different Re (the one at DP and the one at OD) and I've checked the y+, there is an almost negligible difference between the two (the higher y+ changes from 1.1 to 1.3), so I think I will use the same mesh
May 21, 2019, 20:21 |
hector
Rep Power: 7 |
How can i check the y+ number.
May 22, 2019, 01:59 |
M
Rep Power: 12 |
You can try to estimate it with the Re-Number and the first layer thickness you used, OR run a test simulation and get the values in CFD-Post.
May 22, 2019, 09:51 |
Rep Power: 7 |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 12:01 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
