Bladegen Angle Notations
Like Tree2Likes
  • 1 Post By subodh_12
Old   December 13, 2018, 15:30
Default [CFX] [TurboSystem]Bladegen Angle Notations
Subodh Ranjan
subodh_12 is on a distinguished road
Dear all,
I'm having trouble understanding the angle notations used in BladeGen. I looked through the ANSYS Help section and that is also not of much help here. I have to simulate the impeller and inducer section(I want to simulate them individually) of the centrifugal turbopump feed system used for rocket applications.
I have attached a summary of the specifications of the impeller and the inducer [For more detail please refer to Pg. 217 of NASA SP-125]. How can I develop a BladeGen model given that I have the velocity triangle at the inlet and the discharge? Is this enough to accurately model in BladeGen, and if not then what else is needed to be calculated?
I thank you for your help in advance!
Cheers!
ssmacae likes this.
subodh_12 is offline   Reply With Quote
Old   December 14, 2018, 15:20
Subodh Ranjan
I really need your help here.
Would really appreciate if anyone can share their thoughts on this.
ssmacae likes this.
bladegen, cdx, impeller, inducer, velocity triangles
[BladeModeler] Bladegen Radial Impeller Wrap Angle - Help Required surajkashyap ANSYS Meshing & Geometry 1 April 5, 2019 14:24
[Other] Stagger angle in bladegen mzha0001 ANSYS Meshing & Geometry 0 October 12, 2016 19:52
about theta angle in bladegen xyq916 ANSYS 1 June 10, 2015 07:55
Theta angle definition in BladeGen Raul CFX 2 November 1, 2012 12:02
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
