October 16, 2018, 13:11 |
Making it Rain
Saif Ul Malook
Rep Power: 8 |
I just want to simulate falling rain with a 2mm droplet size and the ability to vary the volumetric flow rate of the rain into the domain. It didnt seem difficult with dispersed fluid method but Im not getting natural results. Anybody can help?
October 16, 2018, 19:38 |
Rep Power: 144 |
Are you doing this with a Lagrangian or Eularian model? Why?
What results are you getting?
October 17, 2018, 10:41 |
Saif Ul Malook
Rep Power: 8 |
Was Using a Eularian model with dispersed fluid. Trying to model an Air Curtain roof. I have since moved to using the Particle Transport Fluid method (Langrangian). It seems to be working, now my main concern is momentum transfer (drag force) from air jet into water particles. I dont know which model works best.
October 17, 2018, 18:50 |
Rep Power: 144 |
What is an air curtain roof?
The choice between Lagrangian and Eularian particle tracking methods should not be done on which model you can figure out, but on which model is more suitable for your application. Why do you say the results are not good? What results are you getting? Please post some images and your CCL.
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 04:04 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
