August 23, 2018, 13:51 |
overlap of two meshes
phd
Rep Power: 13 |
Hi, guys
If I want to embed a small mesh into the large mesh of a flow passage. Is it possible for CFX to merge the small mesh into the large mesh? I.e. is it possible for CFX to deal with the overlapping volume of two meshes? I ask this because otherwise I have to empty the space in the large mesh while generating the large mesh. I know that CFX’s powerful GGI interface system can automatically deal with the overlapping part of two mesh surfaces. Although I haven’t found any documents to suggest that CFX can deal with the overlapping volume. Thank you very much! |
August 23, 2018, 19:06 |
Rep Power: 144 |
CFX cannot handle overlapping meshes. You need fluent for that.
The only exception is the immersed solids model uses an overlapping mesh approach, but this is only to model the solid region in a meshed region. GGI interfaces are used to join mesh regions together where the mesh does not match at the interface. You can do a fine mesh around your region of interest and a coarse mesh further away and join them with a GGI, CFX can do this if this is what you want to do.
August 26, 2018, 06:44 |
phd
Rep Power: 13 |
Ghorrocks, thank you very much for your always helpful answers!
overlapping grid |
Mapping (interpolation) between two meshes | Ebrahim | OpenFOAM Programming & Development | 2 | June 15, 2020 13:31 |
[mesh manipulation] Multiple overlapping meshes | koala | OpenFOAM Meshing & Mesh Conversion | 1 | February 1, 2017 05:53 |
How can I put the data of adpated meshes on the original unadapted meshes? | xh110120 | FLUENT | 2 | March 11, 2016 02:00 |
Hex and Tet meshes - simplefoam comparison | danvica | OpenFOAM Running, Solving & CFD | 10 | January 4, 2013 01:18 |
Getting prism to inflate into mixed tet-hex meshes | Joe | CFX | 16 | October 10, 2011 07:06 |
