1-Way FSI CFX to Mechanical - Imported loads (pressure/forces) not matching? |
Moustafa El-sawy
Rep Power: 8 ![]() |
Hi everyone, I am trying a very simple example of flow going through a 90 degree bend pipe. After my CFX sim, which I verify the results with hand calcs for a simple 90 degree bend pipe flow, I import the load (pressure) to a static mechanical analysis and expect to get the same forces I get from CFD?
However, when I look at the imported loads summary I find that they dont match. Is this due to a meshing issue or how does ANSYS Map the pressures from CFD to nodal forces in static mechanical? Does my solid (pipe) mesh has to match exactly the fluid (water inside pipe) mesh at the interface between them? It shows 100% of forces are mapped but they still dont match (not within 5% of each other) Here is what the imported load summary shows: https://imgur.com/a/biVualR My current mesh in ANSYS Mechanical is alot more finer which is recommend by looking at the documentation provided by ANSYS (take a look here at the bottom of the page): https://www.sharcnet.ca/Software/Ans...teraction.html Your feedback is appreciated. |
Rep Power: 144 ![]() ![]() ![]() ![]() |
FSI can handle non-matching meshes.
Does the force balance improve when you refine the mesh?
Moustafa El-sawy
I did not try several meshes, but I did notice the results do vary greatly when the mesh is different. I was hoping someone had experience with this issue. Maybe ai can try several runs tomorrow with different meshes (although I am still fairly new to usinf ANSYS workbench) and post here to help anyone with a similar issue.
If your results are changing between meshes that is a big sign your mesh is not fine enough. There is no point looking at other issues until you have a mesh fine enough to be accurate.
Moustafa El-sawy
My CFD results are converged and dont change with changing ghe mesh. I am talking about the import load step, thats what changes and even with a super fine mesh (the screenshot shown) it still doesnt match. You can try a very quick example of a simple pipe with a bend. Would you like me to upload my model?
Erik
Rep Power: 23 ![]() |
Just checking, is the position and orientation of the pipe elbow the same in both models?
There seems to be a pretty huge discrepancy here. |
Moustafa El-sawy
Yeah they are the same exact model. I am importing the geometry from CFD to mechanical using workbench. You are free to do a quick trial using a simple geometry. The results change with different mesh in mechanical but they never seem to match close enough to be reliable?
#8 | |
power
Rep Power: 4 ![]() |
Hi Did you solve this problem? I am confronting the same issue. in my case, the pressure load which is plotted in Fluent is not the same as the imported pressure which is shown in Ansys Mechanical. |
#9 |
Rep Power: 33 ![]() |
Wrong forum?
#10 |
power
cfx, fsi, mechanical coupling, unidirectional |
problem with creating artery thickness for FSI methode using fluent and mechanical | raminostadi | FLUENT | 1 | June 6, 2020 05:17 |
In Workbench Mechanical, create a script to import external loads | grahamrigs | ANSYS | 0 | April 20, 2017 18:05 |
CFX FSI Fatal Error | unbanana | CFX | 0 | October 3, 2015 05:57 |
Mechanical fails, MAPDL doesn't..FSI | KeganLeckness | Structural Mechanics | 0 | August 17, 2015 16:34 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 04:47 |
