How to create solid-fluid interface in CFX?
Like Tree2Likes
  • 1 Post By cfd seeker
Old   August 6, 2018, 07:24
Default How to create solid-fluid interface in CFX?
Hamda
Hamda is on a distinguished road
I need to define an interface between solid (spheres) and Fluid (the space between spheres). I was wondering if I should return to the first stage, Geometry creating or meshing to define solid-fluid interface or I can create it at the current stage (CFX)?
Many thanks
Hamda is offline   Reply With Quote
Old   August 6, 2018, 07:31
cfd seeker is on a distinguished road
The patches/surfaces which needs to be defined as Interfaces should be defined as separate parts or surfaces. Then in CFX it would be easy to identify those patches/surfaces and set them as interfaces. Like it would be easy to identify them with their names in CFX-pre.
Regards
Hamda likes this.
cfd seeker is offline   Reply With Quote
Old   August 6, 2018, 08:01
Hamda
Thanks
you mean that I should define the common surface by using name selection? But when I want to save it I got error! should I mesh it separately?
Old   August 6, 2018, 08:19
I do the meshing in ICEM CFD. But you have to name the common surfaces as some logical names in the geometry module so that you can define them interfaces in CFX-pre.
Hamda likes this.
Old   August 6, 2018, 11:29
Hamda
Thanks. But as you see in geometry section, I have 2 parts, solid and fluid that are separated from each other. I don't know it is correct or not but I was told that if you want CFX itself creates the interface you should unite these fluid and solid and indeed in geometry section I have just one geometry. I don't know it is correct or not. What is your idea? I asked my questions in different sites and got different answers and so it makes me confused!
By the way, I will try that.
Thanks
Old   August 6, 2018, 11:42
I haven't dealt with interfaces since long, so I kind of forgot it how I was doing it. I am kind of guessing it, just give it a try.
Combine the solid and fluid parts in Design Modeler and then at the joining interface/face you will get a single surface. In CFX-pre define this surface/face as Fluid-Solid interface.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 22:25
