ali pourahmadian
Rep Power: 8 ![]() |
i'm trying tu simulate oxygen absorbtion from water to water vapor and there is vapor condensation happening at the same time. i choose varriable composition mixture for both water and vapor but the thrermal phase change option in not available any more in mass transfer. what should i do to simulate phase change
and another question. when i use varibale composition mixture how can i use IAPWS liberary to calculate saturation propertises. is it done buy automatically by using ideal mixture? |
Xuesong Wang
Rep Power: 0 ![]() |
Hi, i meet the same problem of you, do you find the solutions of this?
phase change material |
Need help to Simulate Phase change of Water liquid after mixing with Hot Air Stream | diineshns | FLUENT | 0 | March 17, 2018 06:14 |
Mass Transfer without Phase Change in InterPhaseChangeFoam | Parisa_Khiabani | OpenFOAM Running, Solving & CFD | 5 | May 26, 2015 09:40 |
Separation of phases in Variable Composition Mixture | Hamilton | CFX | 6 | November 28, 2014 03:36 |
Multiphase flow using variable composition mixture | Helten | Main CFD Forum | 0 | March 11, 2014 09:57 |
help needed about phase change | Yanhu Guo | Main CFD Forum | 4 | January 23, 2001 23:16 |
