Same results for different ambient temperature in ANSYS CFX
Like Tree2Likes
  • 1 Post By Opaque
  • 1 Post By evcelica
Old   July 17, 2018, 05:58
Default Same results for different ambient temperature in ANSYS CFX
Jinu Varghese
jinuvarghese is on a distinguished road
Hi all,
Please help me to resolve an issue that I got with the same results for two different conditions for CHT analysis in ANSYS CFX.
Initailly, i did a CHT analysis in cfx with the ambient temperature as 105C. Then i repeated the analysis with the same setup with the ambient temperature as 20C, but i ended up getting the same temperature rise exactly the same as that of first one.
My setup consists of a closed enclosure (top and bottom cover), inside it both the PCB and ICs are placed, inside air is also modeled. Cooling channel is provided on top cover, diesel at -6.11 c is flowing through it.
Mass flow rate of diesel is 0.0019Kg/s (laminar flow)
Outside temperature of top and bottom cover is set as ambient temperature.
is this is the correct way to define the operating conditions?
kindly help me resolving this.
jinuvarghese is offline   Reply With Quote
Old   July 17, 2018, 21:02
Opaque will become famous soon enough
If you refer to outside temperature, I must assume you are using a Heat Transfer Coefficient boundary condition; therefore, you have not specified which value for the HTC you are using.
The solution will be different if the heat flux through those boundaries is meaningful, if it is nearly zero, I would expect the same solution.
jinuvarghese likes this.
Opaque is offline   Reply With Quote
Old   July 18, 2018, 01:15
Jinu Varghese
Thanks for your reply.
Yes it is heat transfer coefficient boundary condition.
I dont have any airflow on outside so i defined h value as 0.01W/m2K.
Enclosure material is aluminium.
Old   July 18, 2018, 18:23
Erik
evcelica is on a distinguished road
0.01 W/m^2/K is way too low of a coefficient. Natural convection would usually be more like 5 W/m^2/K.
This low of a heat transfer coefficient means is basically does nothing, so yeah, I'd expect the same result regardless of ambient temperature setting.
evcelica is offline   Reply With Quote
Old   July 19, 2018, 01:46
Jinu Varghese
Thanks to Opaque and evcelica.
When I changed the heat transfer coefficient to 5W/m^2K it is working,getting different results for different ambient temperature.
Thanks...
FSI simulation in ansys cfx Arash67.m CFX 1 September 29, 2017 10:52
The ANSYS CFX solver exited with return code 1. No results file has been created. kan8vicky@gmail.com CFX 4 April 26, 2016 03:10
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
comparison with analytical results (1D)and(3D) CFX Rogerio Fernandes Brito FLUENT 1 December 2, 2012 07:12
Reading CFX-CFD results without Ansys CFX JAY ANSYS 2 July 7, 2009 17:48
