volumetric heat source
Like Tree1Likes
  • 1 Post By ghorrocks
Old   March 29, 2004, 05:32
Default volumetric heat source
ioana
Hi everbody!
I have to model a simple fire, that in other cfd code was set as a volumetric heat source. Does CFX 5.6 have this feature?(i was looking in help and i coudn't find something about this). Thank a lot, ioana
Old   March 29, 2004, 19:40
Default Re: volumetric heat source
Hi ioana,
Yes, CFX5 has volumetric heat sources.
Glenn
Old   March 11, 2014, 14:13
Default Volumetric Heat Soruce
Michigan
azhao is on a distinguished road
Is this volumetric heat source linearly distributed in the fluid domain?
Or this heat source term is each cell based, the value depending on the cell velocity or flow rate?
Thanks!
azhao is offline   Reply With Quote
Old   March 11, 2014, 18:06
There are not many people still around after 10 years but I am still here. A bit older and crustier but still here.
You can define a volumetric heat source as constant or as a function of just about anything. So it can be set per control volume if you want to.
karachun likes this.
Old   March 11, 2014, 21:47
Michigan
Hi Glenn,
Ok, is the source value uniformly distributed to each cell in the control volume?
Thanks,
Allan
Old   March 11, 2014, 21:53
The whole point of a control volume is that a single value of the variable is representative of the entire control volume. This applies to the source term as well.
But note there is an exception to this - the integration points in CFX means that fluxes are calculated more accurately than if based on simple control volumes with single values. But this is just being pedantic.
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
How to set a heat source with period heating fluboy FLUENT 0 December 10, 2009 12:52
how to load the heat source to wall david yang Main CFD Forum 1 October 12, 2009 14:34
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
moving heat source Mehdi FLUENT 0 March 24, 2008 18:32
