May 8, 2018, 20:08 |
Definition of local variables in mass source
phd
Rep Power: 13 |
Hi, guys:
I have known that when we use mass source, if the continuity source is negative (a mass sink), the values we specify will be ignored by the solver, and local solution variables will be used as shown in Mass (Continuity) Sources in the CFX-Solver Theory Guide Ch1.8.3. Mass (Continuity) Sources: https://www.sharcnet.ca/Software/Ans.../i1300172.html May I know what is the definition of the 'local solution'? Is it the value at current time step? For example, in 1st order implicit time scheme, at time step n, will the 'local solution' be the variable value at time step n or time step n+1? When the simulation is running the iterations will the 'local solution' vary with the iterations? And how can we express this 'local solution' in the CCL in CFX-Pre Thank you very much! |
May 9, 2018, 09:45 |
Rep Power: 33 |
local solution = control volume value at the current iteration
mass source term |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 11:59 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
