How to overcome highly distorted elements problem in fluid-structure interaction anal |
April 28, 2018, 09:37 |
Nazanin mollahmadi
Dear All,
I'm involving in a 2-way FSI problem simulation of blood flow in arteries(transient structural + CFX) which includes big structural deformation. I have used very small time step for transient structural part as well as system coupling part. However, system coupling delivers "highly distorted elements error" or " Element has excessive thickness change." every time I run the problem. when I run system coupling it return highly distorted elements error for the first iteration, even for very small time steps (1e-7sec).I change the "under-relaxation factor" less than 1 to 0.0001 but this error did not remove.Anyone has any idea how to solve this issue?? Thanks, |
April 29, 2018, 08:02 |
Rep Power: 144 |
This suggests that despite your efforts so far the motion is still numerically unstable. Try even smaller time steps. If that does not work then get a little more desperate by modifying your material to be stiffer and heavier to see if that stabilises things - if you can get that to run you might be able to complete a time step and then you can see the motion and might be able to see what has gone bezerk.
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | ANSYS | 0 | July 22, 2016 14:40 |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | FLUENT | 0 | July 22, 2016 14:39 |
Fluid Structure Interaction | Apollo | Main CFD Forum | 5 | July 4, 2011 17:15 |
Fluid Structure Interaction with FreeFem ++ | Pierre | Main CFD Forum | 1 | November 21, 2008 00:42 |
Simple structure & fluid interaction | Bren | Main CFD Forum | 13 | August 10, 2007 15:22 |
