Combined erosion (cavitation+silt) problem tubine by ANSYS-CFX..possible? |
April 19, 2018, 10:43 |
Md Rakibuzzaman
To all CFX users,
Can CFX simulate the hydroturbine that have 3 phases involved? 1. solid particle . 2. water as continuous phase. 3. water vapor to see the effect of coupled three phases model in turbine. I am using ANSYS CFX and can simulate two-phase both solid-liquid and liquid-vapor phase but I couldn't find any multiphase models which can be simulated 3 phases model. In CFX, at the same time as treating solid particle with Eulerian model in one simulation?? Actually, I want to check the effect under combined erosion (cavitation+sand/silt). Thanks you for your reading and suggestion. |
April 19, 2018, 19:06 |
Rep Power: 144 |
Yes, CFX can do this. I understand there are some restrictions but I don't know that level of detail. Give it a go and see how it works - and carefully validate and verify your work before using the results.
April 19, 2018, 22:24 |
Md Rakibuzzaman
Thank a lot for your kind reply.
April 20, 2018, 04:28 |
Gert-Jan
Rep Power: 28 |
You might be able to use the water-steam-EOS. This allows you to model liquid water and steam as a system in equilibrium. Depending on pressure and temperature, the equilibrium can shift to more steam and less water, or vice versa.
Remember the system assumes equilibrium in each numerical element. As such the mass transfer is assumed infinitely fast, which might be an acceptable assumption in your case. For water-steam-equilibrium system check Theory guide paragraph 1.2.2.3.4 |
Pump Cavitation Analysis in ANSYS CFX | techCAE | CFX | 6 | July 3, 2013 07:37 |
silt erosion in ansys 12 | tarang | CFX | 0 | February 20, 2012 16:58 |
[HELP!] ANSYS v13.0 CFX WINDOWS DISTRIBUTED PARALLEL PROBLEM | luv2luv | CFX | 0 | December 9, 2011 00:05 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 05:47 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
