Find the target file in CFX-interpolator
Like Tree1Likes
  • 1 Post By ghorrocks
Old   April 6, 2018, 12:42
Default Find the target file in CFX-interpolator
phd
lostking18 is on a distinguished road
Hi, Guys and gals, when we use the CFX-interpolator to interpolate the results from the source file to the target file, where can we get the interpolated data?
I know in ‘Run Definition’ mode, the target file is written in the CFX-Solver working directory and deleted at the end of the run, could anyone tell me which file I should look at? Or if we manually use the CFX-interpolator in CFX-Solver Manager, when the .res source file successfully interpolated into the .def mesh file, where can we find out the interpolated results?
Thank you very much!
lostking18 is offline   Reply With Quote
Old   April 7, 2018, 07:04
If you save a results file on iteration zero (either as a steady state or transient simulation) it will put the initial condition in the results file under time step/iteration zero. This is how I check initial conditions.
I thing you can interpolate onto a def file and then load the def file in CFD-Post and you should be able to see the normal velocity, pressure etc variables. I have not done that to confirm but I think that is the case.
lostking18 likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   April 7, 2018, 15:46
phd
Hi, Gleen: Thank you very much for your nice suggestions. I have tried in CFX and you are right, it works perfectly!
interpolation
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
