Rep Power: 14 ![]() |
Hi All,
I need some help with the CFX functions. I would like to run a transient simulation by reading a csv file every time step. Until now, I was computing only steady state by reading .csv files which look like: [Data] x [ m ],y [ m ],z [ m ],Velocity [ m s^-1 ], Temperature [ K ]... 0, 1, 15, 5, 284.211 1, 2, 15, 1, 284.55 ... My User functions look like: LIBRARY: CEL: &replace FUNCTION: Top Argument Units = [m], [m], [m] File Name = myPath/Top.csv Option = Profile Data Profile Function = On Render Type = Points Spatial Fields = x, y, z DATA FIELD: Temperature Field Name = Temperature Result Units = [K] END DATA FIELD: Velocity Field Name = Velocity Result Units = [m s^-1] END END Now i would like to switch to transient simulations and read a file for every time step (delta t=1s). Does someone has a Tipp how to do that? My first idea was to change in the csv files my x,y,z with x,y,t as my boundaries can be defined with only 2 coordinates. The input file become: x [ m ],y [ m ],t[ s ],Velocity [ m s^-1 ], Temperature [ K ]... 0, 1, 0, 5, 284.211 1, 2, 0,1, 284.55... 0, 1, 1, 5, 284.211 1, 2, 1, 1, 284.55... Do you have an idea how to read the new files by doing an interpolation with respect to time? Thanks in advance! |
Rep Power: 144 ![]() ![]() ![]() ![]() |
First of all - if the function is known in advance it can be entered as a CEL expression. But I assume the function is complex enough that this is not practical.
I think you are going to have to do write a user fortran function to do this. Have a look at the example user fortran examples in the CFX documentation on how to do this.
#3 | |
Lance
Rep Power: 22 ![]() |
Creat or Import 2D airfoil profile. | Jackie | FLUENT | 14 | May 11, 2013 06:16 |
How to specify a transient profile with spacial variant without UDF? | joy2000 | Fluent UDF and Scheme Programming | 0 | February 6, 2013 08:51 |
Transient Profile with case modification | nenazarian | FLUENT | 1 | September 28, 2012 17:55 |
Import transient cfx-results for static structural analysis in Ansys WB 13 | Colt Seavers | ANSYS | 1 | August 11, 2011 06:01 |
Writing profile data at transient heat transfer analysis | Ama | FLUENT | 0 | July 5, 2009 07:35 |
