February 28, 2018, 09:38 |
Immersed solid
Tufan Özyıldız
Rep Power: 9 |
i have a discs which i have to rotate,is anyone have a tutorial?
thanks with respect |
February 28, 2018, 18:26 |
Rep Power: 144 |
Tutorials on immersed solids are available on the ANSYS customer webpage.
But if you are modelling spinning discs you do not need immersed solids to do this. A normal wall boundary with a tangential velocity will model it much more accurately and more easily.
March 2, 2018, 03:53 |
#3 | |
Tufan Özyıldız
Rep Power: 9 |
with respect |
March 2, 2018, 04:25 |
Rep Power: 144 |
You can make the tangential velocity a function of time or anything else you like. It does not need to be constant.
A normal wall with a tangential velocity is more accurate when applicable as you can mesh proper inflation layers and get good resolution on the boundary layer. You cannot do this nicely with immersed solids.
March 2, 2018, 07:00 |
#5 | |
Tufan Özyıldız
Rep Power: 9 |
i think discs torque higly related to flow momentum and boundary layer effect how can i define tangential velocity which is related to boundary layer effect and momentum ? UDF? with respect |
March 2, 2018, 20:18 |
Rep Power: 144 |
You can define a tangential velocity in the CFX-Pre GUI using simple CEL expressions. It is very simple stuff.
March 5, 2018, 09:52 |
#7 | |
Tufan Özyıldız
Rep Power: 9 |
I think we have 3 options. One is immersed solid, second is overset mesh in fluent third one is to use dynamic mesh. But third option is a heavy and complex solution. Under the lights of these info, is there any recommandations ? Thanks in advance |
March 5, 2018, 11:20 |
Gert-Jan
Rep Power: 28 |
Why do need such complicated approaches? It looks like you trying to kill a mosquito with a bazooka. Really unnecessary.
For this application: - Forget Immersed Solid. By far not accurate enough. - Forget Overset mesh. Too demanding in terms of computer resources since it requires very small timesteps (at least in Star-CCM+). - Forget Dynamic meshing. Unecessary complex. As Glenn already mentioned the only option is: Let your domain with Tesla Turbine rotate with an increasing speed (CEL Expression) and let the outerwall counterrotate to have it stand still. Use a fine mesh it you really need to solve the complete boundary (Y+<1?). You write that the flow drives your turbine. How can flow drive a Tesla turbine? That is almost impossible since the discs are flat. You have tangential inlet? Even then the torque will be small. Nevertheless, in the simulation you have to set a rotational speed. This can be a function of the (by CFX calculated) torque on all discs (and shaft) using a CEL expression. |
March 7, 2018, 10:46 |
#9 | |
Tufan Özyıldız
Rep Power: 9 |
https://www.youtube.com/watch?v=mrnul6ixX90 in tesla turbine purpose is finding of the shaft rotational velocity and with that finding of power. i dont get it ,if you define tangential velocity by yourself you cant define all of those effect with respect |
March 7, 2018, 11:33 |
#10 |
Gert-Jan
Rep Power: 28 |
Nice video, but you have an ill posed problem and should think for yourself first.......
The velocity of your turbine is determined by balance of the energy you put in (tangential inlet) and the energy you take out. So you need to know what is it drving and how much torque this requires......... - Is it driving a dynamo? This will result in a low speed. - Is it nothing, meaning freely rotating in the air? This will result in a high speed. But then you need to know the friction of the seals and include the drag with surrounding air. You somehow should provide CFX with this input. Don't expect CFX, to know the application beforehand and sets the rotational speed for you. |
March 7, 2018, 17:45 |
#11 |
Rep Power: 144 |
The normal way of determining operating speed in devices like this is you simulate a range of operating speeds and get a torque versus speed function. You then look at your system and determine the torque versus speed function for the system it is driving. Where the turbine function intersects the system function is your steady state operating point.
March 23, 2018, 04:56 |
#12 | |
Tufan Özyıldız
Rep Power: 9 |
March 23, 2018, 05:13 |
#13 |
Rep Power: 144 |
You simulation a range of rotation speeds as steady state (possibly frozen rotor) simulations. You extract the torque on the rotor to get a torque versus speed curve. Then you plot your system torque versus speed curve and the intersection of those two curves is your steady state operating point.
March 24, 2018, 11:10 |
#14 | |
Tufan Özyıldız
Rep Power: 9 |
Flow over a flat plate as an immersed solid | hamed.majeed | CFX | 4 | September 8, 2016 15:40 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Immersed solid, vs solid-fluid interaction to determine forces on a submerged solid | amrbekhit | CFX | 0 | January 8, 2015 17:39 |
Immersed Solid Momentum Sources inside function | Martinw | CFX | 1 | October 10, 2013 18:14 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
